My winter project ... |
Dec 7 2010, 10:55 PM
Resident German Group: Admin Posts: 41,648 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Hopefully, this thread will help me keep track of all the things i want to do to the car this winter. (IMG:style_emoticons/default/screwy.gif)
Consider this my public notebook ... (IMG:style_emoticons/default/biggrin.gif) Parts needed (Parts i already have are marked with [X]): ---------------------------------------------------------------------------------- [ ] - Fiberglass GT front bumper (Getty ?) [ ] - Fiberglass GT lower valance (Getty ?) [ ] - Fiberglass GT rocker panels (Getty ?) [X] - Fiberglass rear 916 bumper. [ ] - Front oil cooler ducting. [X] - Fiberglass flares, extra wide, 9" front and 11" rear [X] - New wheels and tires. Fikse FM10's, 9x17 with 245-45 and 11x17 with 315-35 (Hoosier Dot R's). [ ] - Boxster brake calipers front/rear. [ ] - Boxster brake caliper adapters. [ ] - Front brake ducts and shields. [ ] - Second Sparco Evo-L seat for the passenger. [ ] - Evo-L mounting brackets. [X] - Front belly pan. [X] - Rear removable trunk floor. [ ] - Additional tubing to brace the front and rear shock towers. [ ] - Additional tubing to brace the rear lower suspension mounts. [X] - Front FreeMotion roller bearings. [X] - GT style door pulls. [ ] - New battery. [ ] - New fuel filter. [ ] - New oil filter. [ ] - New set of side mirrors. (Brand???) [X] - JWest fuse panel. [X] - Camp914 fog lights. [X] - 100W head lights. [X] - JWest fog-light flasher setup. [ ] - Stronger clutch setup. (Stage III ???) [X] - Front Euro turn signals. [ ] - Rear Euro lenses. [ ] - Sound deadening material. [ ] - Roll bar padding. [X] - New carpet kit. [ ] - Wide angle, roll bar mounted rear view mirror. [ ] - Correct oil pressure sender. [X] - Old style 911 combi-instrument. Work needed: ---------------------------------------------------------------------------------- [ ] - Remove current FG flares, bumpers and rockers. [ ] - Add new flares. [ ] - Add/modify new rockers. [ ] - Add/modify new bumpers and valances. [ ] - Replace rear decklid and remove spoiler from the old one.[ ] [ ] - Add Boxster brakes and adapters. [ ] - Add bracing to the shock towers and suspension mounts. [ ] - Fix oil line leak. [ ] - Change oil. [ ] - Change remaining two spark plugs. [ ] - Add custom seat braces and mount racing seats. [ ] - Mount 5-point harness. Add harness loops to the rollcage. [ ] - Replace vertical rollcage tube on the pass. side with a bend one for more room. [ ] - Re-weld rollcage joints. [ ] - Seam-weld (parts) of the chassis. [ ] - Repair long damage from the celette pulling. [ ] - Replace top with early style. (New seals?) [ ] - Rebuild steering rack. [ ] - Replace steering rack rubber donut with solid one (If needed?) [ ] - Add GT style door pulls. [ ] - Redo fuel pump box and mounting. (Go with larger supply lines?) (Use the high flow pump?) [ ] - Fix fresh air blower. [ ] - Clean up the wire mess for the 3.6L brain. [ ] - Fix fuel line routing in the engine comp. [ ] - Fix drivers door latch. [ ] - Cap off heater ducts in the engine comp. [ ] - Add JWest fuse panel. [ ] - Install upgraded fuse block. [ ] - Install new headlights and foglights. [ ] - Add mount for front license plate. [ ] - Install new side mirrors. [ ] - Fix throttle cable routing on engine. [ ] - Add front euro turn signals. [ ] - Add rear euro lenses. [ ] - Touch up paint where needed. [ ] - Add sound deadening. [ ] - Redo roll bar padding. [ ] - Install carpet kit. [ ] - Install new rear view mirror. [ ] - Redo "916 targa" badge. [ ] - Fix GT engine lid. [ ] - Add rain shield for engine air intake. [ ] - Black out engine cover side-vents. [ ] - Add/fix charcoal canister and tank venting. [ ] - Fix tank filler seal leak. [ ] - Add padding to front swaybar. [ ] - Corner balance and align the car. [ ] - Powdercoat remaining suspension pieces. [ ] - Add front air-diverter (Removable, under the valance). I'm sure i missed a few things, i'll update this list as i go along ... (IMG:style_emoticons/default/santa_smiley.gif) ... |
Lo-Fi Version | Time is now: 19th May 2024 - 02:42 PM |
