FS - 914 Remote Oil Cooler Setup |
tomeric914 |
Dec 8 2010, 08:36 AM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
I'm converting to a 6 and don't need this setup anymore.
This is a complete oil cooler setup that places the cooler next to the transmission. All nuts, bolts, brackets, wiring, hoses, adapters, pictures, etc. needed to install are included. Individually, parts were ~$500 not including my time to engineer and install everything. Result was a drop in temperature of at least 20 degrees on the street and 40 degrees at the track. I will also include a new Baldwin B228 oil filter. This setup is temperature controlled and enabled when the ignition switch is turned on. Fan turns on at 180 deg F and pulls through the oil cooler. Asking $250 plus shipping for the complete setup. Major parts list below: QTY 2 - Fitting, Hose End, AQP Socketless, Straight, -8 AN Hose Barb to Male 3/8 in. NPT, Brass, Natural, Each - Part Number: AER-FBM1206 QTY 1 - Fitting, Hose End, AQP Socketless, 90 Degree, -8 AN Hose Barb to Female -8 AN, Aluminum, Red/Blue, Each - Part Number: AER-FBM1533 QTY 1 - Fitting, Hose End, AQP Socketless, 120 Degree, -8 AN Hose Barb to Female -8 AN, Aluminum, Red/Blue, Each - Part Number: AER-FBM1543 QTY 1 - Hose, AQP Socketless, Rubber, Blue, -8 AN, 10 ft. Length, Each - Part Number: AER-FCV0810 QTY 1 - Temperature Controlled Sandwich Adapter, Oil Filter, Sandwich, Aluminum, Natural, 3/4-16 in. Thread, 3/8 in. NPT Inlet/Outlet, Each - Part Number: DER-15702 QTY 1 - Derale Cooling Products Atomic-Cool Remote Fan Mounted Fluid Cooler, Tube-Fin Type, Aluminum, 9.375 in. x 12.75 in. x 4.313 in., -8 AN Inlet, Outlet - Part Number: DER-15950 QTY 1 - Relay, Starter/General Use, 30 Amp, Single Pole, Each - Part Number: VIA-80237 Picture below from when it was first installed. It may not be as clean anymore. |
JmuRiz |
Dec 8 2010, 01:38 PM
914 Guru Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
What are you using for your 6? I was told by Rich Johnson such a setup can be fine for a street-use 914/6 auxiliary cooler.
I plan on keeping mine, and just selling the sandwich adapter when I sell my complete 2.0/4 setup. Mine doesn't have that cool thermostatically controlled fan though, where'd you buy it...PM me the details. |
tomeric914 |
Dec 9 2010, 08:25 AM
The diameter on this cooler setup is not large enough for the oil flow of a 6. What I have is everything someone with a 4 cylinder needs to drop their oil temps.
Look at my ad. All of the part numbers are there. Plug those part numbers into Summit Racing if you would like more details. What are you using for your 6? I was told by Rich Johnson such a setup can be fine for a street-use 914/6 auxiliary cooler. I plan on keeping mine, and just selling the sandwich adapter when I sell my complete 2.0/4 setup. Mine doesn't have that cool thermostatically controlled fan though, where'd you buy it...PM me the details. |
tomeric914 |
Dec 12 2010, 04:14 PM
(IMG:style_emoticons/default/icon_bump.gif) Price is negotiable.
tomeric914 |
Dec 18 2010, 07:13 PM
Holiday price reduction, $250 plus shipping
tomeric914 |
Jan 7 2011, 10:38 AM
Last chance to get this cooler here. Next step is eVilBay.
rdr |
Jan 7 2011, 11:04 AM
Newbie Group: Members Posts: 47 Joined: 13-November 08 From: Baltimore, Md Member No.: 9,749 Region Association: North East States |
How negotiable is the price? :-)
tomeric914 |
Jan 7 2011, 12:27 PM
tomeric914 |
Jan 23 2011, 02:04 PM
Maybe I wasn't clear. This is EVERYTHING needed from the thermostatically controlled oil filter sandwich adapter all the way to the oil cooler. Wiring, relay, etc. are all done. You just need to bolt it all in.
Lo-Fi Version | Time is now: 7th June 2024 - 08:54 PM |
