Lightweight Battery Poll |
carr914 |
Dec 13 2010, 06:24 PM
Racer from Birth Group: Members Posts: 118,899 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
What do you guys think?
McMark |
Dec 13 2010, 06:31 PM
I think it's called a personal massager.
Attached image(s) |
agentblr |
Dec 13 2010, 07:24 PM
Member Group: Members Posts: 303 Joined: 23-January 04 From: Lee's Summit MO Member No.: 1,595 |
SLITS |
Thanks Mark ... now I know what they are supposed to be used for. Will it start my /6 and keep the clock accurate?
agentblr |
Dec 13 2010, 07:29 PM
Attached image(s) |
underthetire |
Dec 13 2010, 07:30 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Excide Orbital.
brp986s |
Dec 13 2010, 07:55 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
I have an Oddysey 925 in my 3.2. It's small, 21 lb, and has no problem turning my engine, even mounted up front.
Here's another racing battery: http://www.dekabatteries.com/default.aspx?pageid=4 |
bfrymire |
Dec 13 2010, 08:08 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
I am using an Odyssey battery also, and I like it. But, I found that they sulfate really easily. Keep it on a battery tender if it sits for long periods of time.
-- brett |
sean_v8_914 |
Dec 13 2010, 10:21 PM
best for what? race car? street car? nascar?
campbellcj |
Dec 14 2010, 12:31 AM
I can't Re Member Group: Members Posts: 4,547 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I dunno about best, but I've been using the Odyssey PC680 with no probs. I am on my 2nd one but the first one lasted 6-7 years so no complaints there.
carr914 |
Dec 14 2010, 07:20 AM
Here's another option I found this morning - Super Lightweight - under 12 lbs
http://www.lithionicsbattery.com/racing.html |
stugray |
Dec 14 2010, 09:07 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
brp986s,
"even mounted up front." You relocated your battery up front? I was considering doing this. I was worried that the heavy gauge wire that would be required to run to the back would be so heavy that it would counter any benefit of relocating the battery. Can I get more info? I have a fuel cell in the spare tire well, so the entire gas tank area is empty. Stu |
Root_Werks |
Dec 14 2010, 05:04 PM
Village Idiot Group: Members Posts: 8,331 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I've been running an Odessey 680 since April, works fine.
Root_Werks |
Dec 14 2010, 05:08 PM
This is a picture from my battery drain thread a while back:
Very small and light battery. I've had good luck with it so far. Would it turn a 914-6 over? Maybe, but probably not very fast. Spins my stock 2.0 over just fine. Attached image(s) |
J P Stein |
Dec 14 2010, 06:04 PM
The Odyssey 680 weighs 11 lbs & spun over my 10.5:1 2.7 just fine for 5 -6 years......still going. (IMG:style_emoticons/default/biggrin.gif)
mwyatt |
Dec 14 2010, 06:17 PM
Member Group: Members Posts: 84 Joined: 5-April 03 From: San Diego, CA Member No.: 516 Region Association: Southern California |
Are you guys using the Odyssey 680 in street cars? I'd be concerned about starting the car after multiple short trips. I'd love it if it works...
J P Stein |
Dec 14 2010, 08:14 PM
There are a lot of starts & stops with a 2 driver car at an AX.....no problems.
smg914 |
Dec 14 2010, 09:37 PM
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
Although I have one in my 914, I never considered the Optima a lightweight battery. If anything I would call it a heavyweight battery, weighing in at 38 pounds.
mskala |
Dec 15 2010, 08:57 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Odyssey 680 works fine in street car, been using one for years, even in moderately cold weather.
Root_Werks |
Dec 15 2010, 11:01 AM
I've only been running mine since April of this year, but there have been plenty of cold days (some down into the teens even) and the 680 seems to do just fine. The only downside is the smaller batteries don't have much storage. Storage isn't needed in something like a 914 in my opinion. It only hurts when you have a battery drain like I did a few months back. My L-Jet double relay was sticking on and it drained that little battery in just a couple of hours. The 680 works great, but there isn't much storage capacity there. |
Lo-Fi Version | Time is now: 31st May 2024 - 08:19 PM |
