end cap install, installing window/door end caps late model |
eastbay851 |
Dec 21 2010, 01:14 PM
Newbie Group: Members Posts: 39 Joined: 29-November 10 From: california Member No.: 12,438 Region Association: None |
hi all. i have a bit of a modified 75.... 13b rotary, 911 front end, scraped and filled, camera-monitor system in place of rear views and i am now stumped.... silly i know. after re-upholstering the door panels i went to install the new (914rubber) door/window end caps and cannot do it. the window glass is in the way of the inside screw. do i have to drop the window assembly to install these 2 insignificant widgets? you could probably sense my frustration. this is like traveling across the pacific to finally getting to hawaii and the tide is out so you can t dock and you have to walk the last 200 yards(meters for you euros.) thanks for your help.
76-914 |
Dec 21 2010, 03:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
IIRC, you can loosen the regulator enough to drop the window out of the way. I think that f*&^%ng little phillips screw was a major PITA.
r_towle |
Dec 21 2010, 05:08 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
no need to drop it.
Need less coffee, better light and glasses... You can do it. Rich |
markb |
Dec 21 2010, 05:13 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
A slightly magnetic screwdriver helps a lot, too.
dr914@autoatlanta.com |
Dec 21 2010, 05:17 PM
914 Guru Group: Members Posts: 7,894 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Mark hit it. No reason to drop anything. You can roll down the window and access the inner channel screw with a magnetic phillips screw driver through the hole in the fuzzy window channel. It is easy and should take ten minutes (if you are slow) to change both!!!!!
Of course the small outer screw is a piece of cake. hi all. i have a bit of a modified 75.... 13b rotary, 911 front end, scraped and filled, camera-monitor system in place of rear views and i am now stumped.... silly i know. after re-upholstering the door panels i went to install the new (914rubber) door/window end caps and cannot do it. the window glass is in the way of the inside screw. do i have to drop the window assembly to install these 2 insignificant widgets? you could probably sense my frustration. this is like traveling across the pacific to finally getting to hawaii and the tide is out so you can t dock and you have to walk the last 200 yards(meters for you euros.) thanks for your help. |
eastbay851 |
Dec 21 2010, 05:20 PM
no need to drop it. Need less coffee, better light and glasses... You can do it. Rich i can do the light and the glasses but no coffee? that s just cruel. i m 57 with a prostate the size of a cantaloupe. it takes me 4 cops of coffee just to get my boxers off in the morning... AFTER showering in them. |
Mikey914 |
Dec 21 2010, 05:21 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
If you can post some pictures, maybe something different we haven't seen before is going on here. Collectively, maybe we can figure out a solution for you.
-mark |
eastbay851 |
Dec 22 2010, 09:05 AM
look doc, i m sure you are the best ever but do you really want to tell a guy who has done a full roto conversion and all that entails that "...It is easy and should take ten minutes...?" seems if it were easy i would have done it that way eh? anyway.... thanks everybody who tried to help. i just bit the bullet and dropped both window mechanisms and installed the screw. it should be mentioned that i had rebuilt the window mechs. and re-installed the windows and the entire structure was very well adjusted (re: no give in any direction) prior to looking at these end caps. dropping the window mechanisms and installing the screws took "ten minutes." i just can t believe that these things were mass produced with the end caps going in first. i would have thought that all rubber would go on last. thanks again everybody.
windforfun |
Dec 22 2010, 11:47 AM
Senior Member Group: Members Posts: 1,835 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
I cut perfect rectangular slots in mine so I wouldn't have to remove the inside screw. It's not exactly stock, but the screw is difficult to keep hold of even with a magnetic driver. FYI & have a nice day.
EdwardBlume |
Dec 22 2010, 12:20 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
Its a nice piece. I installed these on mine after reassembling the door and while its a PITA, you can do it.
Lo-Fi Version | Time is now: 8th June 2024 - 12:45 AM |
