HELP!!! 8 hours till AX |
jdogg |
Apr 24 2004, 09:09 PM
Member Group: Members Posts: 431 Joined: 28-January 03 From: Youngsville, NC Member No.: 204 |
Following up this thread: http://www.914world.com/bbs2/index.php?act...=ST&f=2&t=11327
I busted ass today trying to find the leak and narrowed it down to the hole in this pic...What is this? When you look inside the plenum, there is a tube that runs from top to bottom. Does it go to something, or is it just support for the intake?....Can I just seal it with epoxy? Duct tape seems to have done the trick for right now..... PS. This hole is located on the forward side of the motor. Attached image(s) |
415PB |
Apr 24 2004, 09:17 PM
Member Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 |
It's just a support tube. Epoxy will do the trick for now, but you might want to weld it later.
jdogg |
Apr 24 2004, 09:56 PM
Thanks Rod.....I think duct tape is actually gonna have to do it for tomorrow, then we'll weld! I didn't look closely, is that all mild steel there? Can I just zap it with my mig welder?
415PB |
Apr 24 2004, 10:06 PM
Yep, it's a mild steel and your mig should work just fine. I hope it works out. Let me know how it turns out and dont you just love duct tape (IMG:style_emoticons/default/smile.gif)
EdwardBlume |
Apr 24 2004, 10:11 PM
I've gone through a plenum or two. Make sure you have the plastic bolt behind the accelerator pedal. If you don't or if its not stopping the pedal, you may over torque the cable when you floor it, and the first thing that gives is your flimsy pleum, not the thottle.
Lo-Fi Version | Time is now: 8th June 2024 - 04:14 AM |
