rwilner |
No Ghosts in the Machine ![]() ![]() ![]() Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States ![]() |
I got my trans out of the car, packed, and shipped down to Richard Casto at Blue Sky for a rebuild.
![]() ![]() ![]() My question is, what other work should I do now, or parts should I replace? the obvious stuff -- - new CV joint bolts (8) - paper cv joint gaskets - trans fluid (duh) the cv boots look to be in good shape. Is there anything else obvious I should be doing with the trans out of the car? thx Rich |
montoya 73 2.0 |
Lack of consideration to others, and Selfish! ![]() ![]() ![]() Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California ![]() |
Check and replace with all new Shift bushings, Also new Cone screws (very important)! Maybe even check your clutch and cable? Oh and your throw out bearing.
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Drew hit it on the head. Also, you do not need the paper CV gaskets. They shrink and expand allowing for the bolts to come loose and fall out. Many have abandoned the gaskets, including myself, and now just bolt the CV on, clean the outer mating surface with solvent, and seal with high temp silicon. Works good (IMG:style_emoticons/default/smile.gif)
Dr Evil |
Oh ya, read the 31 pages of notes below to find little nuggets of info to keep things running smooth. (IMG:style_emoticons/default/thumb3d.gif)
rwilner |
Thanks guys. Shift bushings and clutch cable are all new. Dr, I will check out your thread.
Dr Evil |
You should be good to go (IMG:style_emoticons/default/thumb3d.gif)
jim912928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,487 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest ![]() |
Transmission mounts while it's out if they are old/original!
rwilner |
thanks Jim, PO replaced them with solid ones.
Sounds like i'm in good shape! |
Dr Evil |
Solid ones are not friendly for street use. Have you driven with them yet? If so and you like them, no worries. But, I would recommend the 911 mounts. Stiffer, still rubber, last forever, cost less than 914 OE ones.
montoya 73 2.0 |
I just remembered the 2 alignment roll pins! They should be roll pins not solid pins.
Dr Evil |
Richard should notice that and correct it if there are solid pins. Not hard to do. It looks like one or more are still stuck in the CV.
montoya 73 2.0 |
rwilner |
Hey Dr
My car rattles my teeth over bumps -- PO set it up for AX with 140lb rear springs and these solid mounts. Are the 911 mounts available at the usual suspects (AA/PP)? |
Dr Evil |
Yup, GPR can hook you up as well. They are my preferred parts whores (IMG:style_emoticons/default/biggrin.gif)
Richard Casto |
Blue Sky Motorsports, LLC ![]() ![]() ![]() Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States ![]() |
Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
Don't forget new Schnorr washers.
rwilner |
Don't forget new Schnorr washers. Thanks Cevan -- actually, when i took the bolts off, there were no washers! (IMG:style_emoticons/default/dry.gif) Richard -- I was taking inventory last night and realized I sent you my TO bearing and clutch fork in the bell housing. I apologize for that. If you want to hang on to them that's great, if not, ship them back to me and let me know how much $$. |
Richard Casto |
Don't forget new Schnorr washers. Thanks Cevan -- actually, when i took the bolts off, there were no washers! (IMG:style_emoticons/default/dry.gif) Richard -- I was taking inventory last night and realized I sent you my TO bearing and clutch fork in the bell housing. I apologize for that. If you want to hang on to them that's great, if not, ship them back to me and let me know how much $$. It's no big deal at all. About 1/2 show up that way anyhow. I only ask to not ship them as if I don't have them I can't loose them! Either way, everything sent to me gets sent back. I take an inventory when the transmission arrives. (IMG:style_emoticons/default/smile.gif) Richard |
Dr Evil |
I always have a designated box for each transmission so I know what came off of which and where to send it (IMG:style_emoticons/default/smile.gif)
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
CV bolts drilled for safety wire...
Lo-Fi Version | Time is now: 3rd July 2025 - 04:16 PM |
