monkeyboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None ![]() |
I have the early doors with the window regulator buttons. I have a new set of buttons. How do I get the old buttons out? I have tried to pry on them a little, but they aren't budging. Is there something I missed?
Hopefully I don't have to take the door apart again. (IMG:style_emoticons/default/sad.gif) |
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
They're held in by a pair of prongs in the center of the button. The button has a tendency to want to come off, so if yours is on there that strongly, why replace it? Unless they're broken leave them in. If they are broken, pinch the prongs together & pull the button off. Press the new button on, and spread the prongs as wide as you can.
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I agree if the button stays on leave it.
watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
I have a later window regulator and also the new buttons. I'd like to replace mine since they are worn down so much that they jump out of the track. How do I replace them?
-- Rob |
21783mike |
Glutton for Punishment ![]() Group: Members Posts: 18 Joined: 13-July 11 From: Smithsburg, MD Member No.: 13,310 Region Association: MidAtlantic Region ![]() |
May I ask where you purchased the buttons from..... mines missing on the driver side.
monkeyboy |
AA I think.
21783mike |
markb |
We have a bag of good used ones. How many do you need? Cheaper by the dozen..... (IMG:style_emoticons/default/biggrin.gif)
monkeyboy |
21783mike |
We have a bag of good used ones. How many do you need? Cheaper by the dozen..... (IMG:style_emoticons/default/biggrin.gif) Only need 1 but should get 2 in case I need one in the future. You can email with details - mikesmowing@myactv.net |
Mikey914 |
Got the new ones in Delrin. They pop off with a plyers amd you can pop them on the same way. Do them in sets (2 per window) because you will not have to take it apart again for the other later. Lube the track with a little grease.
Lo-Fi Version | Time is now: 4th July 2025 - 07:54 AM |
