| Tom |
Dec 28 2010, 11:48 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Anyone know about any interesting articles to share about camless engines?
Here is one link. http://autospeed.com/cms/title_Camless-Eng...10/article.html Having infinitely variable cam timing would open so much performance and economy it just boggles my little mind! And not having cam chains to worry about would be something positive also. Just imagine a 2 liter type 4 with heads that would essentially have dual overhead camshafts with infinitely variable valve timing. WOW!! Tom |
| rick 918-S |
Dec 28 2010, 01:24 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,239 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I have a friend that worked as an instructor at an advanced BMW tech training center. I was at the school and he showed me some BMW heads that had solinoids or something that were running the valves. Very cool. No loss of HP turning cams, no verio parts to fail.
| r_towle |
Dec 28 2010, 01:34 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
From the article (which is dated)
QUOTE International Truck and Engine Corp is another engine manufacturer poised to take a huge step forward in diesel engine design, announcing that it will eliminate camshafts from its diesel engines and replace them with electronic-valve timing systems by the year 2007 Did this happen? Rich |
| r_towle |
Dec 28 2010, 01:37 PM
begs to question.
Do valves need to be round? A square port slide mechanism may be more durable and easier to build... How about a triangle? Rich |
| flipb |
Dec 28 2010, 01:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,871 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region
begs to question. Do valves need to be round? A square port slide mechanism may be more durable and easier to build... How about a triangle? Rich For that matter, do they need to be shaped like valves at all? If electromechanically operated, couldn't it be something akin to a hinged "trap door" design? |
| RJMII |
Dec 28 2010, 01:48 PM
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
QUOTE For that matter, do they need to be shaped like valves at all? If electromechanically operated, couldn't it be something akin to a hinged "trap door" design? like reed valves for a snowmobile or motorcycle engine? |
| Chris Hamilton |
Dec 28 2010, 02:13 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 |
Do valves need to be round? Yes, they have to be able to rotate freely in the valve guide. I've seen what the destruction looks like when they can't rotate anymore. (IMG:style_emoticons/default/smash.gif) |
| jd74914 |
Dec 28 2010, 02:50 PM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,875 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Round are easiest to seal as well.
I'm not sure why they would need to rotate; it is a different application, but many high quality industrial valves are non-rotating to keep from scratching the seats (and hence ruining the sealing surface). |
| RJMII |
Dec 28 2010, 05:40 PM
They rotate to seat better. When we switch valves in a head ina car we spin them on purpose with valve lapping compound to assure that the seat shape and the valve shape are identical and provide a really good seal. Round is easier to assure the seal because of the ability to spin them in this procedure.
| PlaysWithCars |
Dec 28 2010, 09:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 541 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest
Look closely at the alignment between a rocker and the valve stem. Where the adjuster contacts the valve is slightly off center to rotate the valve a little bit each time it is moved.
| PlaysWithCars |
| Dr Evil |
Dec 28 2010, 09:33 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Round is necessary. Points would focus heat and break down from heating up. Think how you have to smooth the combustion chamber to guard against hot spots.
| Rand |
Dec 28 2010, 09:40 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,414 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Rotary cam is nothing new. (google it)
Compact nuclear... Now that's where it's at. Seriously though, rotary makes sense. Even if as primitive as centrifugal timing variation, it's all rolling with the flow. On the contrary, solenoid-driven, or anything else that relies on stop and go motion is way more complex and inefficient and prone to quick wear (and thus more frequent adjustments to stay within spec). |
| jd74914 |
Dec 28 2010, 09:42 PM
They rotate to seat better. When we switch valves in a head ina car we spin them on purpose with valve lapping compound to assure that the seat shape and the valve shape are identical and provide a really good seal. Round is easier to assure the seal because of the ability to spin them in this procedure. I understand that lapping is used to match the valve/port together in order to promote good sealing. You do this whenever you assemble an industrial valve or, like you said, head. The part I don't understand is the necessity of valve rotation while the motor is running. At that point there is no guarantee of even surfacing, and any crap that gets on the seat can randomly scratch it, messing up the sealing surface. |
| Rand |
Dec 28 2010, 09:54 PM
QUOTE The part I don't understand is the necessity of valve rotation while the motor is running. At that point there is no guarantee of even surfacing, and any crap that gets on the seat can randomly scratch it, messing up the sealing surface. You might be surprised how much valves rotate. Just by nature, it happens. I've seen some great videos... Maybe a link to one will show up soon. |
| kevin311 |
Dec 29 2010, 06:18 AM
Member ![]() ![]() Group: Members Posts: 105 Joined: 22-May 10 From: Tampa Bay Area Member No.: 11,752 Region Association: None |
http://www.pattakon.com/pattakonDesmo.htm
Maybe not camless but it's definitely a new way to use a cam. This site has some really cool designs and some cool animations to show the function, I'm not sure where I stumbled across this site but I spent like 2 hours reading all the pages |
| SGB |
Dec 29 2010, 08:10 AM
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Whoah!
Thas some cool chit. I wonder if any of these ideas wil reach production. |
| ME733 |
Dec 29 2010, 09:49 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
..........most all TWO cycle engines....(as we call them)....have no valves...as we Normally think of valves....and no camshaft....In past years their have been very few engine designers who have attempted to utilize this simple method applied to cars....In the diesel truck engine world their are "two" cycle engines....Their must be some reason this simple system has not been refined /developed for cars, but I certanily miss the point....Diesels turning 1200 rpm, or motorcycle engines turning 12000 rpm, surely their is some one smart enough to design a variable RPM /torque/HP , two cycle engine.
| KaptKaos |
Dec 29 2010, 10:10 AM
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Obvious?
(IMG:http://www.914world.com/bbs2/uploads_offsite/reedmantoll.us-607-1293639003.1.jpg) This is what I thought of when I saw the title. I don't have much else to add. |
| charliew |
Dec 29 2010, 10:13 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
Two cycle is just that. Twice as many power pulses as 4 cycle. As in 12 cylinders 4 cycle compared to 6 cylinders 4 cycle. Most 2 cycle motors are tuned with an exact exhaust system for the utmost power. The ones I am familiar with are not fuel efficient. My 350cc 2 cycle 69 kawasaki twin made 42 hp. It used a rotary disk on the crank with a notch in it letting the intake port open before the piston started up. Wider notch = more duration and more power at high rpm. Expansion chamber exhaust to tune the power band. When a rotary valve would come loose on it's splined sleeve on the crank the motor would have one cylinder that would only make power at one rpm and it would vary with how much the valve would free spin.
Lo-Fi Version | Time is now: 2nd April 2026 - 11:08 AM |
