oil cooler seals, small winter project |
914 shifter |
Jan 2 2011, 10:33 AM
airhead Group: Members Posts: 266 Joined: 28-August 10 From: ny/nj Member No.: 12,111 Region Association: North East States |
i am going to order a set of oil cooler seals from pelican.has anyone purchased these? pelican has an article on this subject/install.looks like a real pita, but i do believe i have a leak/drip in this area so i will order seals tomorrow.they are only $1 each i just want to be sure they are the best choice. assuming there is a choice. (IMG:style_emoticons/default/cheer.gif) happy new year!
brant |
Jan 2 2011, 10:43 AM
914 Wizard Group: Members Posts: 11,633 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I've always found pelican parts to be great
factory stuff GPR also has great stuff and really good prices. that is one pain in the butt job though... something to do when the motor is out brant |
detoxcowboy |
Jan 2 2011, 10:46 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
They are good and work fine; Carefull with that Pelican article about doing it without taking anything out of the way; in the end it is easier to just do it correctly rather squeeze and fumble those seals into place. Plus if done correctly you will get a better look at what is going on and where the leak is really comming from. MY friend whom as dismanlted at least a dozen 914's, tried it the Pelican article way and spent more time doing it that way trying to avoid work than just do it with work involved but no struggle.. That is just my 2 cents.
Don't look at it as work but as time spent, in the end it equals out so why not do the work and spend the time doing it right.. |
realred914 |
Jan 2 2011, 10:53 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
i am going to order a set of oil cooler seals from pelican.has anyone purchased these? pelican has an article on this subject/install.looks like a real pita, but i do believe i have a leak/drip in this area so i will order seals tomorrow.they are only $1 each i just want to be sure they are the best choice. assuming there is a choice. (IMG:style_emoticons/default/cheer.gif) happy new year! make sure the leak is not from the oil pressure sendor, that often is a leak that appear to come from the cooler. the oil pressure sendor can fail at the seam between the metal housing and the plastic inner part. It is cheap and fast to fix this before the oil cooler seals. I have had more failures of the oil pressur esendor than the oil cooler seals. so check that out first. if you dont want to buy a new sendor et, simply use a pipe plug (1/8 inch NPT) in place of the sendor for a while and see if the leaks goes away, if it does, then the oil sendor was either loose or leaking at the seams. may you have a leak free year!!!! |
bandjoey |
Jan 2 2011, 11:18 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I did the Pelican method and it wasn't hard to do. I got the car up on 4 stands and had pleanty of room. Take off the heater elbow itsjust a couple of bolts. Pull off the oil filter neck to get to the top nut of the cooler - order a gasket. Used an open end wrench with vasoline to stick the seals in place and it took about an hour. U just have to enjoy working under the car. (IMG:style_emoticons/default/smash.gif)
detoxcowboy |
Jan 2 2011, 11:24 AM
I did the Pelican method and it wasn't hard to do. I got the car up on 4 stands and had pleanty of room. Take off the heater elbow itsjust a couple of bolts. Pull off the oil filter neck to get to the top nut of the cooler - order a gasket. Used an open end wrench with vasoline to stick the seals in place and it took about an hour. U just have to enjoy working under the car. (IMG:style_emoticons/default/smash.gif) I think on condoms they tell you not to use vasoline as it deteriorates the rubber and may cause un-safe sex. |
914 shifter |
Jan 2 2011, 01:28 PM
thank you all for the info. i will order a new pressure sender $5, and the seals $2.i will install the new pressure sender first then i will ask for the 914 god for mercy (IMG:style_emoticons/default/laugh.gif)
ChristopherB |
Aug 1 2011, 07:53 PM
Member Group: Members Posts: 93 Joined: 18-May 11 From: Towson, Md. Member No.: 13,086 Region Association: MidAtlantic Region |
I am a total newbie and I am investigating an oil leak. Well, using "an" is not really appropriate as I am sure I have more than one. I am hoping it is the oil cooler seals and I am in the process of replacing them. My first question is how the heck do you remove the top nut on the oil filter neck? Mine is right up against the cooler and I can't get a wrench on it. Is it possible to remove the cooler without removing the filter flange? Also, does the cooler come out with the bracket attached?
Thanks, Chris |
type47 |
Aug 1 2011, 08:15 PM
I don't think you remove the cooler, just unbolt it enough to move the cooler away from the engine case to remove the old seals and install the new. You "can't" remove the cooler with the fan housing in place: if you really plan to remove the cooler, drop the engine, it will save time in the long run.
ChristopherB |
Aug 2 2011, 02:06 PM
Thanks Jim, that helps a lot.
My real problem is the top nut on the filter flange. The cooler sits right on it, and I can't get anything on it. |
r_towle |
Aug 2 2011, 02:12 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
1/4 socket wrench, a ujoint or three, long extension and some time and patience.
All you need to do is pull the cooler away from the case about 1/2 and inch ...the old seals can be flicked free with a screw driver. Then, with grease on the new seals, I slide them up into place with a pair of long tweezers....they will stick long enough with the grease on them to get the cooler back in place. Rich |
Cap'n Krusty |
Aug 2 2011, 02:20 PM
In close to 40 years, I can't remember ever actually seeing a T4 oil cooler seal that failed, i.e., leaked. Coolers, many, oil pressure switches, all the time, but never the seals.
The Cap'n |
Drums66 |
Aug 2 2011, 03:25 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
.......if the car has been idle for 35 yrs or they're as hard as a rock!
replace them, it's real easy!! (IMG:style_emoticons/default/idea.gif) (I drop the oil filter (IMG:style_emoticons/default/idea.gif) ) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
bigkensteele |
Aug 30 2011, 06:33 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
I did mine a couple of years ago. Arm yourself with lots of light, an aresenal of curse words and vasoline or grease to stick them in there. I don't remember removing the oil filter console.
All that being said, I now have my motor pulled, and now that I can see everything, it was never leaking from the cooler seals. Everywhere else, yes, but the seals were fine. My guess is your front main seal or the pressure sender. My main seal was leaking and given its proximity to the fan, it has blown oil all over the place. |
Lo-Fi Version | Time is now: 4th June 2024 - 12:01 PM |
