> Oil Galley- Bus Case Issue
tornik550
post Jan 9 2011, 10:16 PM
I decided earlier today to use a bus case for my rebuild. I had it laying around, it is a very nice case. I started to take the oil galley plugs out just like I have several times before on 914 cases. I ran into an issue that I hadn't on previous cases.
On the galley plug behind cylinder #1 near the flywheel side, there is a metal tube that runs from the rear cam bearing to the mechanical fuel pump boss. The tube blocks the galley and makes it so I cannot tap the hole. Since I am not running a mechanical fuel pump, can I just drill through the metal tube so that I can tap the galley hole?
Replies(1 - 6)
bam914
post Jan 9 2011, 10:48 PM
You will need to remove the bronze bushing and tap it too.
Mark Henry
post Jan 10 2011, 07:41 AM
that's what I do!
You can just punch the tube out. You have to tap and plug both sides (pic#2 and 3) of the pump rod hole. Then you must make a block off plate for the pump mount.
You also need a block off (on the other end) for the oil fill tube and you'll have to figure out a dipstick.
Jake Raby
post Jan 10 2011, 08:37 AM
Engine Surgeon
You should have read my article before you started. That plug didn't need to be removed since uts a fuel pump case.
As Mark states, yu'll have to tap both sides of this galley, else you'll have no oil pressure!
tornik550
post Jan 10 2011, 08:55 AM
QUOTE(Jake Raby @ Jan 10 2011, 09:37 AM) *
I am actually trying to do everything right this time so I actually did read the article. The problem was that I read it prior to doing the plugs on my 914 case. I didn't even pay attention to the part about the bus case because it was irrelevant at the time. Oh well.
mrbubblehead
post Jan 10 2011, 09:23 AM
Twodollardoug
QUOTE(Jake Raby @ Jan 10 2011, 06:37 AM) *
where is this article located?
Jake Raby
post Jan 10 2011, 10:52 AM
Engine Surgeon
All my articles are on my forums.
Not all bus cases have a fuel pump, just 72-74 carbureted engines..
- Lo-Fi Version Time is now: 3rd March 2026 - 06:21 PM
