mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
Oil tank is out, and basically all the rubber pieces for the mounting studs and
all the foam pieces that are supposed to be seals around filler, vent, and bottom line are all junk. I'm not keen on trying to get all the different factory pieces and was wondering if there are any other ways to make them. For example I just got a couple generic bushings that will probably work for the mounting studs. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,594 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
how thick do they need to be?
There are some foam insulation pieces in the plumbing isle at HD. There is a truck bed mat measuring about 1/4 inch. There is also a horse stall mat measuring about 1/2 inch... Both of those are rubber. Foam pool toys also come to mind...various thickness and bright colors. Rich |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
Always check mcmaster Carr for that kind of stuff. We buy oil resistant closed cell foam from them about once a year.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
how thick do they need to be? There are some foam insulation pieces in the plumbing isle at HD. There is a truck bed mat measuring about 1/4 inch. There is also a horse stall mat measuring about 1/2 inch... Both of those are rubber. Foam pool toys also come to mind...various thickness and bright colors. Rich That's what I was thinking on the oil filter/console hole was a foam (not wax) toilet ring. The wax might work, and you could form it for the filler hole, but it might melt with the engine bay heat. Cheap ass SOB at it finest (IMG:style_emoticons/default/biggrin.gif) (BTW the wax ring comment should be in green text) |
laflaur |
Member ![]() ![]() Group: Members Posts: 162 Joined: 8-June 06 From: Granite Bay Member No.: 6,186 Region Association: Northern California ![]() ![]() |
try the dealer, they had em when I did mine.They were like a closed cell foam. pretty cheap if I remember correctly
Scott S |
Small Member ![]() ![]() ![]() Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 ![]() |
I just ordered mine from Rich Johnson.
r_towle |
sleeping mat from EMS would also work..
If you go to Michaels craft shop, they have alot of it. Or Joannes fabrics also has alot of foam. Rich |
rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
I used the foam weatherstripping you find at hardware stores. Self adhesive and cheap.
mskala |
Good ideas. I was expecting to need to cut circles, but wrapping the self-
adhesive weatherstrip works? Thanks |
Lo-Fi Version | Time is now: 16th June 2024 - 10:13 PM |
