Subaru Throttle Cable Options, What did you use? |
Britain Smith |
Jan 14 2011, 03:55 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I am search for the best option for a throttle cable on the Subaru conversion and I am interested to see what has been done. Let me know what you got.
-Britain |
r_towle |
Jan 14 2011, 04:19 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
string or twine might be perfect if you use the little pulleys that match.
rich |
Britain Smith |
Jan 14 2011, 08:58 PM
Where are the Subaru conversion guys? What did you use to make your car go?
-Britain |
pktzygt |
Jan 14 2011, 09:13 PM
Member Group: Members Posts: 328 Joined: 20-March 07 From: Chesapeake, VA Member No.: 7,611 Region Association: MidAtlantic Region |
You shouldn't have to change it as long as your engine is placed near where renegade puts theirs. Of course I never fully connected mine when I had the engine in, but it looked to be the correct length.
Engine is back on a stand for the time being or I would go take pics for you. |
Britain Smith |
Jan 14 2011, 09:52 PM
I went from a 914/6 throttle cable set-up which I know longer have. In addition, I have changed my pedal assembly to a Tilton set-up. Do most people use the stock 914/4 cable?
-Britain |
Britain Smith |
Jan 15 2011, 10:25 PM
Wow, so nobody wants to share their set-up.
I have been looking at getting this throttle cable, but was wondering if there was an easier way. http://rjes.com/html/throttle_cables.html (IMG:http://www.914world.com/bbs2/uploads_offsite/rjes.com-364-1295151926.1.JPG) -Britain |
TonyAKAVW |
Jan 16 2011, 02:37 AM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I used two throttle cables. I used a normal 914 cable and a normal EJ25 cable. I machined an adapter that joins the two (removable) and then an adjustable mount to hold the sheaths. It isn't elegant or pretty but it has worked for a few years.
Tony |
Rod |
Jan 16 2011, 04:08 AM
Senior Member Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
Hi Britain, Is there not a company over there that can make you the cable exactly as you need?? I have used a company over here in the UK who made a cable exactly my length and also with the correct fittings on either end for the application I had built at the time..
Your car is turning out to be amazing, you don't want a broken TC as your mid corner on full beans.. (IMG:style_emoticons/default/barf.gif) |
d914 |
Jan 16 2011, 09:21 AM
Advanced Member Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
Bob(bigkat) used two cables.. Standard 914 and made an adpater connector to the suby piece..
sawtooth |
Jan 23 2011, 11:08 AM
Member Group: Members Posts: 297 Joined: 25-June 08 From: Boise, ID Member No.: 9,211 Region Association: Intermountain Region |
Stock cable works perfect for me with a slight mod. I cut the old rod type end off and replaced with a 3/8 cable stop. Fits perfectly into the suby throttle cable holder. The cable stop has a set screw but I also plan on filling with solder or braze to make sure it is permanent.
plymouth37 |
Jan 23 2011, 12:31 PM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
Stock cable works perfect for me with a slight mod. I cut the old rod type end off and replaced with a 3/8 cable stop. Fits perfectly into the suby throttle cable holder. The cable stop has a set screw but I also plan on filling with solder or braze to make sure it is permanent. (IMG:style_emoticons/default/agree.gif) I did that before I got a custom cable and never had any problems with it. |
sean_v8_914 |
Jan 23 2011, 12:35 PM
Terry cable will build it to your spec for $40
plymouth37 |
Jan 23 2011, 12:51 PM
Britain Smith |
Jan 23 2011, 06:08 PM
Just ordered my cable from Terrycable, we shall see how it looks when it gets here.
-Britain |
partwerks |
Jan 23 2011, 10:35 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I used the terry cable on mine..........
Lo-Fi Version | Time is now: 10th June 2024 - 06:20 PM |
