> SS Fuel Line question - front tank area, supply versus return exit hole locations?
jim912928
post Jan 15 2011, 01:49 PM
Ok..I'm putting in my new Chris Foley SS fuel lines (excellent by the way)....what I don't remember is which line exits which hole in the front trunk area (I think I have them criss-crossed right now). So, my supply line enters through the hole in the engine side nearest the passenger side of the car. Does it exit in the same (nearest the passenger side of the car) corresponding hole in the front...or does it pop through the hole nearest the drivers side for a more direct path to the fuel pump?
Thanks...Jim
Replies(1 - 2)
sfrenck
post Jan 15 2011, 02:55 PM
QUOTE(jim912928 @ Jan 15 2011, 02:49 PM) *
Thanks...Jim
Chris's lines aren't identical - one is longer than the other. The longer one goes on the driver side (supply), the shorter on the passenger side (return). They should both stick out of the grommet under the fuel tank about the same amount (if you cross them or put the short one on the driver's side, I don't think it will be long enough to go through the front grommet).
jim912928
post Jan 15 2011, 06:30 PM
Thanks for the insight on the lengths. I had them correct on the engine side and criss-crossed them on the tank side. Also had the speedo cable wrapped between them! So, I yanked them out...layed them down..put the shortest on the passenger side..rethreaded and put them through correctly on the tank side with the speedo cable out of the way. So...here is how they landed:
Passenger side holes....9.5mm supply line
Drivers side holes.....8mm return line
Now I can start running all my engine compartment lines. Should look good as I went to the local race shop and got all AN connectors with braided teflon lines. I'm using AN bulkhead connectors to transition the fuel lines from below the engine shelf to above it. Note: my SS lines have the AN connectors welded on.
- Lo-Fi Version Time is now: 12th August 2026 - 04:26 AM
