Pics of brakelight switch?, Oopsies. |
corsepervita |
Jan 19 2011, 04:07 PM
Member Group: Members Posts: 327 Joined: 18-April 10 From: Redmond, OR Member No.: 11,631 Region Association: Pacific Northwest |
Alright so I'm getting the 914 ready and working out all the kinks after the electrical mishap.
I got it all working, everything tested out fine but I got a weird reaction from my wife... "Your brake lights aren't working did you know that?" and i said "nonsense... look" and i'd go push to the floor and they'd come on. What I wasn't realizing is that it would have to be quite far down before it came on. So of course, i took things apart and looked at the switch and it either looks bent, or something is wrong with the switch. It has to depress quite far before it'll actually kick on. I thought "Hm that's odd." If I try and adjust it by moving it further down the large washer that it is on that goes down with the pedal, it'll actually sometimes go too far and past the washer and bam, no light at all. So I re-adjust it and then it only goes on once it's far down. Although I'm assuming the following shouldn't be the case: Should it have lateral play? I am thinking my switch may be busted. Maybe when I was doing the harness I bumped and bent or broke it, because it has some lateral play instead of going back and forth. Anyone have a picture so I can compare? |
dr914@autoatlanta.com |
Jan 19 2011, 04:42 PM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
It is actually engaged all of the time and the pedal holds it off. It is sprung to be on, so when connected should be on until you push the spring loaded finger and then it turns off. I would suggest that if it does not work this way it is bad.
Alright so I'm getting the 914 ready and working out all the kinks after the electrical mishap. I got it all working, everything tested out fine but I got a weird reaction from my wife... "Your brake lights aren't working did you know that?" and i said "nonsense... look" and i'd go push to the floor and they'd come on. What I wasn't realizing is that it would have to be quite far down before it came on. So of course, i took things apart and looked at the switch and it either looks bent, or something is wrong with the switch. It has to depress quite far before it'll actually kick on. I thought "Hm that's odd." If I try and adjust it by moving it further down the large washer that it is on that goes down with the pedal, it'll actually sometimes go too far and past the washer and bam, no light at all. So I re-adjust it and then it only goes on once it's far down. Although I'm assuming the following shouldn't be the case: Should it have lateral play? I am thinking my switch may be busted. Maybe when I was doing the harness I bumped and bent or broke it, because it has some lateral play instead of going back and forth. Anyone have a picture so I can compare? |
jt914-6 |
Jan 19 2011, 05:01 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
To adjust the switch....depress the pedal and put a 4mm (0.16") spacer between the pedal stop and the assm. stop...loosen the adjuster lock nut and screw the adjuster screw until the lights come on.....tighten lock nut...remove 4mm spacer and test lights...should come on just after pedal is depressed......click on this link and click on the switch pic... http://www.pelicanparts.com/catalog/shopca...l_pg1.htm#item2
detoxcowboy |
Jan 19 2011, 05:13 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
corsepervita |
Jan 19 2011, 07:36 PM
Sooooo it sounds like i hooked it up backwards? (edit) no that's how mine looks... man what in the world.
I'll bench test the switch to see if i can duplicate. |
type47 |
Jan 20 2011, 09:30 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
I think it's a simple switch and you can't hook it up backwards. The "lever" from the switch should "ride" on he washer looking metal part so when you push on the brake pedal, the lever moves to operate the switch.
Lo-Fi Version | Time is now: 10th June 2024 - 07:02 PM |
