Black22 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest ![]() |
Hey guys, I got one for you. I searched and did not find this dilemma.
Got in my car for it's weekly run. I noticed that the oil pressure and alt. Lights did not illuminate in the on position of the key switch. I start the car no problem. Them I notice that my Tach and Gas gauge are dead. I rev the car up and they come alive along with the alt light. Car is running and alt light is on. Turn signals don't work. Hazards do. All other lights work. I step on the brake and the gas gauge goes dead. I release brake peddle and gas gauge works again. I thought I read about this a while ago. What is it? Voltage regulator, brake switch, alternator, fuse, relay?!? (IMG:style_emoticons/default/WTF.gif) Thanks in advance for the help and smart ass comments to come. |
904svo |
904SVO ![]() ![]() ![]() Group: Members Posts: 1,126 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 ![]() |
clean fuses 8 and 9.
Cap'n Krusty |
Most folks automatically check the fuses before even thinking about other possible causes. Have you done so? Even if they're all there and intact, spin them in their contacts to check for corrosion.
The Cap'n |
Black22 |
Yeah I checked the fuses. Replaced them all last week but checked them again today.
Black22 |
Just found a disconnected terminal on 9. That was it. Thanks 904svo and Capt. for making me look AGAIN!
speed metal army |
Waiting for the rain to stop... ![]() ![]() ![]() Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada ![]() |
The same thing happened to me..It figures that a fuse knocked out or blown makes everything go nuts! (IMG:style_emoticons/default/biggrin.gif)
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I think DD explained this once...but whenever I here someone say "stepped on the brakes and gas gauge went to zero" its a fuse...must be the number 9 fuse that causes that specific and wierd thing to happen.
He had another one that was I think the starter circuit was somehow wired via a rear tailight....something really funny. Both are stock wiring, just corrosion issues. Rich |
jt914-6 |
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,787 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States ![]() |
Just go ahead and install an Engman fuse panel.....modern fuses....no more kicking out fuses....one of the best upgrades I've done....
Rod |
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England ![]() |
Black22 |
Just go ahead and install an Engman fuse panel.....modern fuses....no more kicking out fuses....one of the best upgrades I've done.... Agreed, My car started to behave once that went in... I'll do that one day...when my wife forgets how much I've already spent on this car! (IMG:style_emoticons/default/blink.gif) I went to my local VW shop and got a fuse cover from a 73 Ghia/ 72 Bug that fits our panel so I don't kick out fuses anymore...and it was only $7 (IMG:style_emoticons/default/piratenanner.gif) Thanks for all the responses fellas...it's good to know people are always here when you're having problems out in the driveway. |
914itis |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States ![]() |
Als914 |
Lighting my way ![]() ![]() Group: Members Posts: 330 Joined: 1-January 06 From: Hemet,Ca. Member No.: 5,346 Region Association: Southern California ![]() |
Just go ahead and install an Engman fuse panel.....modern fuses....no more kicking out fuses....one of the best upgrades I've done.... (IMG:style_emoticons/default/agree.gif) I up graded mine.... lights were brighter, gauge readings stronger and the teener just seem to run better. |
detoxcowboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa ![]() |
or you could just clean and restore your original, it is really just all about clean, correct and good contact connection.. in fact the whole car should be gone through for clean conenctions, the relay board and all its little contacts in the engine and the 7 ground points at the least.. then the fi harness ect.. it one of the cheapest projects available for improvements..
Lo-Fi Version | Time is now: 13th July 2025 - 07:18 PM |
