Rear Trailing Arm removal, I don't get it... |
3liter914-6 |
Apr 27 2004, 02:07 PM
Master of Clueless Posts Group: Benefactors Posts: 310 Joined: 12-October 03 From: State College, PA Member No.: 1,238 Region Association: MidAtlantic Region |
Ok, so I'm going to order up some of them fancy roller bearings for the rear and I'm taking the rear arms off do the 911 e-brake mods and powdercoating at the same time. I've got all the nuts and everything off, but I don't see how to get the bushing studs out of the mounting points? Is there something I'm missing? a brain perhaps? I'm sure I don't want to bend anything, do the studs push back into the trailing arm?
Also, when I took the locknut off the right outer stud, it was really close to the outer fender well, so close when I pried the nut out, the body got pushed out as well (nothing permanent). Is this normal variance on out hand built cars, or is something bent? thanks, Adam |
Mueller |
Apr 27 2004, 02:11 PM
You only need to remove the one 22mm nut on the inside ear and the 3 17mm (or 15mm) bolts that go up into the chassis...these bolts are what hold the outside mount onto the car.
Brad Roberts |
Adam,
put the outside nut back on and semi tighten it. Remove the 3 bolts that hold the alignment shims into place. This will allow the arm to fall down, then you have to slightly move it towards the outside of the car to get the shaft splines out of the inner ear. Be careful. It has some weight to it. It can be done with valances on the car... but you will have to bend it a little out of the way. B |
JWest |
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
You need to remove the mounting bracket on the outside (3 bolts). There will be alignment shims (for camber) above the brackets, so be sure to capture these after removing the bolts.
These bolts are often quite rusted, so take proper measures (PB Blaster, heat) to persuade them to come out. Edit - I'm too slow typing. |
Brad Roberts |
Apr 27 2004, 02:12 PM
What other BBS or email group gives you 3 CORRECT answers less than 10 seconds apart ??
NONE. Thanks for playing. B |
3liter914-6 |
Apr 27 2004, 02:17 PM
QUOTE(Brad Roberts @ Apr 27 2004, 04:12 PM) What other BBS or email group gives you 3 CORRECT answers less than 10 seconds apart ?? NONE. Thanks for playing. B No kidding, I thought I'd at least have time for a bathroom break and get a few pages of Excellence in before heading back out to the garage. Thanks guys! Oh, so the outer nut thing is normal? |
davep |
Apr 27 2004, 02:25 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
QUOTE(3liter914-6 @ Apr 27 2004, 12:17 PM) Oh, so the outer nut thing is normal? The outer nut does not come off until the arm is off of the car, so yes, it is normal. I like to use my air impact wrench to take the bolts out. I have had several break due to extreme rusting. There are supposed to be plastic caps on the top of the bolt holes to seal them. Remove the caps and add penetrating oil. DO NOT FORGET TO REPLACE THE CAPS!!!!!!!!!!!!! |
3liter914-6 |
Apr 27 2004, 02:54 PM
QUOTE(davep @ Apr 27 2004, 04:25 PM) QUOTE(3liter914-6 @ Apr 27 2004, 12:17 PM) Oh, so the outer nut thing is normal? The outer nut does not come off until the arm is off of the car, so yes, it is normal. I like to use my air impact wrench to take the bolts out. I have had several break due to extreme rusting. There are supposed to be plastic caps on the top of the bolt holes to seal them. Remove the caps and add penetrating oil. DO NOT FORGET TO REPLACE THE CAPS!!!!!!!!!!!!! hmm.. No caps, but like the rest of the car, delightfully unrusty. It's off now. Thanks for the help guys. |
Lo-Fi Version | Time is now: 28th May 2024 - 01:23 PM |
