> turbo tie rods, do the ball joints bend?
7391420
post Apr 27 2004, 02:57 PM
I just recieved a new set of the Lemforder turbo tie rods and after taking them out of the packaging, the ball joint at the end is bent-IE the rod is not flat. I am assuming that the ball joint is just rotated a bit, but I cant straighten it by hand so I'm wondering if this is normal, and when installing, it will straighten???
Replies(1 - 6)
Part Pricer
post Apr 27 2004, 03:04 PM
Believe everything I post
I'm a little lost.
Here is a turbo tie rod end. Can you point to the area that you are asking about?
(IMG:http://img.eautopartscatalog.com/live/M301083354LEM.JPG)
post Apr 27 2004, 03:11 PM
Paul,
Thanks, it's actually the other end of the tie rod, which looks like a ball and socket-
to me it looks as if you should be able to rotate it, and so maybe when they were built they just were not put on straight, but I can't rotate the ball joint by hand to straighten it so I just wondering if this is normal, or a part defect..
ArtechnikA
rich herzog
if it weren't supposed to flex, there'd be no need for a joint, now, would there ?
they -are- stiff; what makes the Turbo tie rods better is the zero compliance.
(BTW - i think Paul's picture shows the end that all tie rods have - the fancy 'turbo' part is at the other (inboard) end ...)
post Apr 27 2004, 03:12 PM
so will it straighten out by it's self or do I not even need to worry about it because once it's on it'll move into postion?
DuckRyder
post Apr 27 2004, 03:14 PM
Avatars Mode: OFF because of the recalcitrant few.
once you screw it into the rack you will have enough leverage to move it where you need it.
post Apr 27 2004, 03:18 PM
Cool, Thanks guys I was hoping that was the case..
- Lo-Fi Version Time is now: 1st July 2025 - 10:52 AM
