Anybody use kill switch's for security and ? |
detoxcowboy |
Jan 26 2011, 11:19 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Just curious if anyone uses a "kill" switch for security or otherwise? this is what i used the old bosch switch..
wertygrog |
Jan 26 2011, 11:25 PM
wertygrog Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
I have one (or two).
I use it for peace of mind, and it's good in certain situations where I want to play the stereo without the fuel pump humming away. |
detoxcowboy |
Jan 26 2011, 11:27 PM
I have one (or two). I use it for peace of mind, and it's good in certain situations where I want to play the stereo without the fuel pump humming away. (IMG:style_emoticons/default/agree.gif) peace of mind mostly, plus i do not want to worry where i park and i do go some shady places sometimes.. |
wertygrog |
Jan 27 2011, 01:16 AM
I use it for shady places, and sometimes bring the distributor rotor with me too. I never lock my doors though because I don't want someone busting into the car. If they want to sit inside and make revving noises, they can be my guest. (IMG:style_emoticons/default/smile.gif)
EdwardBlume |
Jan 27 2011, 08:12 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
If they want to sit inside and make revving noises, they can be my guest. (IMG:style_emoticons/default/smile.gif) That's what jackstands will do to you... |
jcambo7 |
Jan 27 2011, 08:28 AM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
If they want to sit inside and make revving noises, they can be my guest. (IMG:style_emoticons/default/smile.gif) That's what jackstands will do to you... (IMG:style_emoticons/default/av-943.gif) I have one also. Hopefully it never has to be tested. |
Root_Werks |
Jan 27 2011, 08:35 AM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I don't have one in my 914, but have thought about installing one. My Squareback has one. I don't use it much, maybe if the car will sit un-driven for a week or longer I'll use it. Or if I'm working on anything electrical, it's nice for that. It's a whole system, battery kill switch.
speed metal army |
Jan 27 2011, 08:38 AM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
I use one.Keeps mysterious fires at bay as well.... (IMG:style_emoticons/default/biggrin.gif)
Dr Evil |
Jan 27 2011, 08:45 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Why not just pull the fuel pump relay and take it with you? Easy and requires no mods.
Cap'n Krusty |
Jan 27 2011, 09:48 AM
pcar916 |
Jan 27 2011, 10:20 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
A simple one works unless you have an DME ignition. A current pulse will need to be shunted to ground through a resistor to protect the computer/voltage regulator when the switch is thrown.
This is a big red switch on the outside of the car but many street cars use the same switch mounted inside the trunk actuated by a cable. Get a good one and buy a spare key at the same time. Good luck! |
Mike Bellis |
Jan 27 2011, 07:56 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I had a buddy that used the cigarette lighter as a kill switch. Used it to power up a main relay. Put it in your pocket and take it with you. 99% of theives will not have an extra plug in lighter with them.
flipb |
Jan 27 2011, 08:25 PM
Senior Member Group: Members Posts: 1,729 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
I had a buddy that used the cigarette lighter as a kill switch. Used it to power up a main relay. Put it in your pocket and take it with you. 99% of theives will not have an extra plug in lighter with them. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.straightrazorplace.com-10752-1296181512.1.jpg) Love that idea. Some PO installed the green knob thingee on the battery of my car. I occasionally unhook it when the car's gonna sit for a while. Very rarely, take it with me when I'm parked somewhere. |
John |
Jan 27 2011, 09:30 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
A simple one works unless you have an DME ignition. A current pulse will need to be shunted to ground through a resistor to protect the computer/voltage regulator when the switch is thrown. This is a big red switch on the outside of the car but many street cars use the same switch mounted inside the trunk actuated by a cable. Get a good one and buy a spare key at the same time. Good luck! Why unless you have a DME ignition? Works on our track car..... |
SirAndy |
Jan 27 2011, 11:16 PM
Resident German Group: Admin Posts: 41,680 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Why unless you have a DME ignition? If you don't ground it through a resistor, you can fry the alternator/voltage regulator ... (IMG:style_emoticons/default/blowup.gif) |
Rand |
Jan 27 2011, 11:25 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I had a buddy that used the cigarette lighter as a kill switch. Used it to power up a main relay. Put it in your pocket and take it with you. 99% of theives will not have an extra plug in lighter with them That has *some* cool factor. And I've also done the "pack the rotor with me" thing. But you's guys are still packing baggage. I go back to my days of wearing only board shorts, and bailing out to the water. I don't want to be packing a key, no less a freakin' cigarette lighter plug. I always went with a hidden switch. No door locks (nobody busted my windows). No nothin.... Sigh, memories. |
TC 914-8 |
Jan 27 2011, 11:45 PM
Senior Member Group: Members Posts: 812 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
I have one too, Some how I figured in the schematic terminal 4(I think) if the 4 prong plug on the relay board has to be grounded to run the fuel pump. I installed a secret switch( only one person knows where it is and how it has to be facing to run, besides me) (IMG:style_emoticons/default/shades.gif) so when I leave the car, I open the circuit and the fuel pump won't run. If anyone wants to try to take a joy ride, I'll find them at the end of my driveway. the v-8 doesnt last too long with out fuel pump running. Any factory 914 wouldent even start with the fuel pump running.
RiqueMar |
Jan 27 2011, 11:54 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
I took a page from my Dad and am gonna put a switch on the little vent that goes inside the door sill. I'de like to see someone get farther than a block w/out a fuel pump.
BiG bOgGs |
Jan 28 2011, 05:48 AM
The Bogus One Group: Members Posts: 452 Joined: 25-September 04 From: Ft. Myers, FL 33967 Member No.: 2,829 Region Association: South East States |
Had a friend who used two switches. One to turn the car power on, and a second momentary switch that rerouted the starter through the horn. After he got it started and released the momentary switch the horn went back to its normal function.
'73-914kid |
Jan 28 2011, 08:12 AM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
I have a regular battery switch (with resistor) that sits on the firewall between the two seats. It's in a great position to just take out the key and clip it on to the regular ignition keys... It's a plastic key too, no water issues..haha But it works well, and is only noticeable to a trained eye for 914's...
Lo-Fi Version | Time is now: 10th June 2024 - 05:01 PM |
