914 shifter |
airhead ![]() ![]() Group: Members Posts: 266 Joined: 28-August 10 From: ny/nj Member No.: 12,111 Region Association: North East States ![]() |
"You can bore the heads for larger tubes and solve the issue, else you'll have to have the correct seals which are NLA as far as I know.. I'd use the old seals and seal them up with my teflon sealant.." this a reply from the classic thread "push rod tube seals."one of my tubes is leaking at the head original 1.7.i was going to order some seals but it appears they are nla? (IMG:style_emoticons/default/hissyfit.gif)
G e o r g e |
Dr ![]() ![]() ![]() Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None ![]() ![]() |
"You can bore the heads for larger tubes and solve the issue, else you'll have to have the correct seals which are NLA as far as I know.. I'd use the old seals and seal them up with my teflon sealant.." this a reply from the classic thread "push rod tube seals."one of my tubes is leaking at the head original 1.7.i was going to order some seals but it appears they are nla? (IMG:style_emoticons/default/hissyfit.gif) http://www.aircooledtechnology.com/store/p...=301&page=1inner seals |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,934 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Many sources. Auto Atl. - Pelican - and others on this site.
G e o r g e |
detoxcowboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa ![]() |
they are all over the place, always check vw sites too.. I have never seen them nla, plus them come in engine gasket sets, i given away sets.. what do you do with them all.. plus there is always someone here on this site whom knows somewhere or has them personally.. (IMG:style_emoticons/default/drunk.gif)
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Just note that the early 1.7 heads have smaller bores for the pushrod tubes than most heads do. AFAIK, you can get the silicone seals for those but the "usual suspects" don't carry Viton seals for the smaller bores.
--DD |
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
Many sources. Auto Atl. - Pelican - and others on this site. (IMG:style_emoticons/default/agree.gif) Pelican, I'll bet even Eric Shea can get those pieces to you... only buy Viton though! |
Lo-Fi Version | Time is now: 6th July 2025 - 12:07 PM |
