Overcrowding in the garage!, It's like the stuff is multiplying.... |
Mike D. |
Jan 30 2011, 03:51 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I'm sure many of you have had this "problem" at one time or another. (IMG:style_emoticons/default/smile.gif) Probably hit the 356Registry Swap in March to unload some junk, (IMG:style_emoticons/default/dry.gif) uh er, I mean nice slightly used Porsche parts.
Attached thumbnail(s) |
Mike D. |
Jan 30 2011, 03:54 PM
All the cabinets and the attac above the garage have also filled in with parts! I don't know how this keeps happening. I had to tell the wife that 914 parts know they are rare and multiply like rabbits when nobody is looking. (IMG:style_emoticons/default/biggrin.gif)
stock93 |
Jan 30 2011, 06:16 PM
Member Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States |
It's critical be to organized with parts to keep clutter to a minimum. Cheap plastic totes from HD are really nice to keep things together. It makes stuff stack up on shelves better to be able to make the most of space. I have one thing that helps with engines on stands. It's a set of shelves that are built where the bottom shelf is high enough to be able roll an engine underneath them while it's still on a stand. At one point I had 5 engines that were not in vehicles in my garage. Getting rid of all of it isn't a good solution either because you'll of course need one of whatever you got rid of recently.
moparrob |
Jan 30 2011, 06:45 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
Getting rid of all of it isn't a good solution either because you'll of course need one of whatever you got rid of recently. (IMG:style_emoticons/default/agree.gif) As Murphy's law would have it, you usually end up needing the thing you just threw out within a week of that date. (IMG:style_emoticons/default/headbang.gif) |
bandjoey |
Jan 31 2011, 12:15 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
My address is........ (IMG:style_emoticons/default/drooley.gif)
Some cool parts there. Get a HF Car garage to put behind the house for storage. |
carr914 |
Jan 31 2011, 09:03 AM
Racer from Birth Group: Members Posts: 118,970 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
That looks pretty roomy in there compared to mine
TJB/914 |
Jan 31 2011, 09:32 AM
Mid-Engn. Group: Members Posts: 4,334 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
Mike-D, cool parts stash!!!!
Here's a tip from your senior member. (IMG:style_emoticons/default/first.gif) I learned this long ago, when you have limited garage space & the wife needs her car space. Listen up now. (IMG:style_emoticons/default/popcorn[1].gif) Never collect heavy iron, motors, etc. they take up space and they are always available when needed (cheap). Collect small hard to find & rare stuff that cost big bucks, like Chrome Bumpers, Fuchs, S.S.heat exhangers, D-Jet F.I. parts, MPS's any NOS stuff, Rare accessory rear fog lights (IMG:style_emoticons/default/happy11.gif) That was for my 914-buddy Pat (IMG:style_emoticons/default/grouphug.gif) It's the little/small things that cost the most when you restore your 914. Tom |
Mike D. |
Jan 31 2011, 10:06 PM
(IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
Thanks for all the advice! I do plan on thinning things out a bit. Forgot to mention there is also a '71 Type 3 Squareback parked next to the house. It will be getting resto to "nice" DD status, with a 2.0 T4 914 engine of course! (IMG:http://www.914world.com/bbs2/uploads_offsite/i936.photobucket.com-85-1296533217.1.jpg) |
ClayPerrine |
Feb 1 2011, 09:12 PM
Life's been good to me so far..... Group: Admin Posts: 15,512 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
You have just learned the first law of 914 ownership.
If you take your 914 apart and put it back together enough times, you will eventually have enough parts left over to build another 914. I have taken our two apart enough times that I probably have enough parts to build 4 more. |
jesiv |
Feb 5 2011, 04:00 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
I see the problem... The Fan is taking up too much room (IMG:style_emoticons/default/piratenanner.gif)
hasaramat |
Feb 5 2011, 05:52 PM
Member Group: Members Posts: 80 Joined: 23-November 08 From: Utah Member No.: 9,782 Region Association: None |
charliew |
Feb 6 2011, 01:02 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
I will use the lower motor buggies like the ones for sbc's that bolt to the motor mounts to get the motors under shelves and I think I will buy some of the furniture dollys from hf to put the flat bottom ones on or the ones in boxes. I probably have too many motors. But I need to build some 4 x 8 two level shelves to get my lighter parts up in order to get more parts. You can never have too many good parts bought pennys on the dollar hopefully. I need a neat way to store 901's and suby trannys also that would let me roll them around. The 901's are for the vw based toys.
flash914 |
Feb 6 2011, 09:52 PM
Member Group: Members Posts: 124 Joined: 1-January 11 From: littlerock CA Member No.: 12,554 Region Association: Southern California |
I'm looking for a power unit for my 70 914-4 the dirty on the ground upfor sale I'm in littlerock ca. Email me at flash2point@yahoo.com
Lo-Fi Version | Time is now: 6th June 2024 - 01:21 PM |
