Help ID some parts, I need some help IDing some 914 parts |
928er |
Apr 28 2004, 12:01 PM
Newbie Group: Members Posts: 7 Joined: 28-April 04 From: Chas, SC Member No.: 1,995 |
Hi, I'm a 928 guy who has been planning to get a 914, but now it looks like we are moving next year so I'll likely hold off till then.
The reason I'm posting is that a while back I bought a bunch of 928 parts from this guy who also had some 914 parts; I bought it all planning on having spare for the future 914, I don't really want to haul any extra parts to the new home so I need to try to sell the extras but don't know a lot about the 914 parts. 1st is a side shift transaxle; is there a reference where I can match the numbers to the rear and/or gear ratios? 2nd is a pair of axles, the guy I got them from said they were HD axles for the 914 (definatly not 928 units); is there some reference for these? I guess I would need to know length from the outsides of the CV joint and diameter of the axle to ID it a2 a HD unit? I also got some new carpet parts plus a yard of matching bulk carpet plus a yard of vinyl, and I think theres a few emblems and such; I'm planning on posting this stuff in the classifieds once I figure out what it all is. |
SirAndy |
Apr 28 2004, 12:09 PM
Resident German Group: Admin Posts: 41,671 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
shoot a couple of pictures and post them here. i'm sure we can help you figure out what you have, Andy |
ArtechnikA |
Apr 28 2004, 12:22 PM
QUOTE(928er @ Apr 28 2004, 10:01 AM) 1st is a side shift transaxle; is there a reference where I can match the numbers to the rear and/or gear ratios? 2nd is a pair of axles, the guy I got them from said they were HD axles for the 914 side shift transmissions - alla same ... (all /4 transmissions alla same ...) 11:34 1st 18:34 2nd 23:29 3rd 27:25 4th 31:22 5th 7:31 R&P AFAIK all the /4 halfshafts were the same. /6 halfshafts are different.. or do you mean stub axles ? /4 and /6 definitely different there, donno 'bout any 'HD' stub axles, but i guess ya never know... could be they're /6 parts in which case you'll definitely have some people interested (like - me, probably ...) |
928er |
Apr 28 2004, 12:44 PM
A little more info:
Axles: 26mm dia.; ~41-42 cm shaft length; ~37-38 length between outer edges of CV joints with joints pushed back; 2 10mm roll pins on each end; the do match up to the drive flanges in the trans. Trans: PN 914.301.302.00 on rear cover; PN 914.303.127.01 on ear over shifter; HA 23 02 3 stamped along bottom rib of trans. If I'm planning on gettin a 914 next year anyhow, should I be hanging on to this stuff?? I know for my '79 928 I'd love to have an extra tranaxle around for rebuilding since they(and mine) have synchro problems. I can get a couple pics up later today also. |
Brad Roberts |
Apr 28 2004, 12:51 PM
Keep it all. You will need it sooner or later.
WELCOME (IMG:style_emoticons/default/clap56.gif) (IMG:style_emoticons/default/clap56.gif) B |
928er |
Apr 28 2004, 01:00 PM
Thanks for the welcome, this sounds like proper 914 parts then?
Here's a pic from inside the toolshed; can add better ones later. (928 has it hemmed in with dead battery...again) Attached image(s) |
JWest |
Apr 28 2004, 01:05 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Yep, just standard 914 side-shift trans and axles - no HD about them (nor does any HD - factory - of those parts exist).
Gint |
Apr 28 2004, 06:09 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Welcome to the Club 928er! (IMG:style_emoticons/default/beer.gif)
Lo-Fi Version | Time is now: 4th June 2024 - 12:28 PM |
