Installing Perlon Headliner |
NJ914Guy |
Feb 5 2011, 11:45 PM
Member Group: Members Posts: 150 Joined: 30-December 10 From: Deptford, NJ Member No.: 12,546 Region Association: MidAtlantic Region |
This in my Sunday project. I have the Perlon and spray adhesive. Do you install only in the flat pan area of the targa top, or does the Perlon roll up the side lips too?
PlaysWithCars |
Feb 6 2011, 12:12 AM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
In my '74 it is only in the flat pan.
Where did you get the Perlon from? I'm looking for a bunch to do the floor and back wall in my -6. |
GeorgeRud |
Feb 6 2011, 12:56 AM
914 appearance has it - he also has a pre-cut piece for the top available.
NJ914Guy |
Feb 6 2011, 01:22 AM
Thanks boys. While cleaning the top tonight, I noticed that the inside front trim strip is missing. It sits between the front targa latches and is fastened to the top with (4) screws. What is this part called? And does anyone sell a replacement?
Thanks -Chuck |
jim_hoyland |
Feb 6 2011, 08:36 AM
Get that VIN ? Group: Members Posts: 9,317 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
TArga top bolster ? I see these at swap meets all the time; put a WTB ad in the classifieds, you should find several to choose from.
Attached image(s) |
detoxcowboy |
Feb 6 2011, 10:00 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
(IMG:style_emoticons/default/skull.gif) (IMG:style_emoticons/default/blink.gif) Warning; Spray Adhesive Liberaly and Evenly over the coverage area.
Summer is right around the corner and the targa top gets hot, .... Just a little advice as the adhesive will hold nicely on first application but when Summer comes the heat will affect the top and you may find out you missed an area in the form of an air pocket,,, |
NJ914Guy |
Feb 6 2011, 11:40 AM
Thanks for the tips. Have the heater on in the garage and will be spraying the 3M super 90 high temp adhesive. Should be OK.
Lo-Fi Version | Time is now: 6th June 2024 - 09:31 AM |
