Oil Pressure sender.. does in need an 0-ring? |
tod914 |
Feb 8 2011, 03:10 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Going to replace my OP sender (the one on top by the distrib.). I couldn't find an 0-ring listed in the PDF. Does it take one or does it just go on without one?
Thanks, Tod |
IronHillRestorations |
Feb 8 2011, 04:06 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
No sealing ring or O ring, it has tapered threads. Don't over tighten it.
tod914 |
Feb 8 2011, 04:08 PM
Thankyou sir.. I'll check the torque sets on it before I install it.
rgalla9146 |
Feb 8 2011, 04:16 PM
Advanced Member Group: Members Posts: 4,561 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Feb 8 2011, 04:31 PM
FWIW, I usually put a thin smear of Permatex aircraft sealant on it.
tod914 |
Feb 8 2011, 04:41 PM
Ok good deal. Thanks guys.
Cap'n Krusty |
Feb 8 2011, 05:10 PM
Be sure you get the correct switch, as many of the modern switches use a copper gasket.
The Cap'n |
tod914 |
Feb 8 2011, 05:24 PM
I ordered the Porsche one Cap'n, from PP. I check it prior to install. Thanks for the tip.
Lo-Fi Version | Time is now: 1st June 2024 - 12:40 AM |
