What's This Hardline Do?, 2.7 Motor |
kconway |
Feb 15 2011, 09:36 AM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
gms |
Feb 15 2011, 09:54 AM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Eric_Shea |
Feb 15 2011, 09:56 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/agree.gif) The dreaded 2.7 thermal motor.
rgalla9146 |
Feb 15 2011, 10:05 AM
Advanced Member Group: Members Posts: 4,563 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Eric_Shea |
Feb 15 2011, 10:11 AM
QUOTE remove and plug at each head (IMG:style_emoticons/default/agree.gif) 10x1 if I recall. The cap we use for the back of the 914 caliper is perfect for this. |
Scott S |
Feb 15 2011, 10:56 AM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Ugh. Ask Ferg how much fun that project can be. Buy some dental tools........
kconway |
Feb 15 2011, 11:02 AM
Thanks! From the comments, sounds like a motor to stay away from for a conversion?
Scott S |
Feb 15 2011, 12:17 PM
There are definitely better - but I am using using a 2.7 for my conversion. The price was right and thankfully all of the 2.7 stuff that needed to be addressed was done by the previous owner (less a couple of exhaust studs!!). Here is pic - I am just a clutch and a set of 914-6 engine tins away from installing it in the car. Hoping for a fun summer! (IMG:style_emoticons/default/driving.gif)
Attached image(s) |
JmuRiz |
Feb 15 2011, 01:13 PM
914 Guru Group: Members Posts: 5,433 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Ooooo, those clear f-glass tins are cool!
You're much further along with your 2.7 than I am. |
Eric_Shea |
Feb 15 2011, 02:24 PM
QUOTE sounds like a motor to stay away from for a conversion? Depends. Buy it right. |
Ferg |
Feb 15 2011, 02:41 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Ugh. Ask Ferg how much fun that project can be. Buy some dental tools........ (IMG:style_emoticons/default/headbang.gif) those tubes that go into the head are super thin, as in hollow, anything more than a "tiny" effort to remove them will result in them snapping leaving threads in the head, I had 3 of 6 snap, 2 of those came out with a reverse bit the last one was hell, dental picks and all. |
pcar916 |
Feb 15 2011, 02:50 PM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
If you do decide to use that motor there are plugs for those air-injection ports. Engine Builder's Supply used to have 'em but they were available from lots of folks.
I had a really nice 2.7L (Bruce Anderson spec) motor in my 914 when I bought it. It was great fun and built to overcome the limitations of the original. But it'll never have the legs (mileage) that a later motor will. I'd never put less than a 3.2L motor in one now unless a really fun 2.7 cropped up. Any more I'm used to having more torque. Kinda makes going back a bit tough. To build a 2.7L motor up properly will cost as much or more than a later motor, although the conversion costs differ a little. The magnesium case has to align-bored (and possibly shaved first) and after oil pump updates and other mods you will still get a motor that can't last as long as a newer one. For some years shuffle-pinning was recommended for those cases until it was discovered that there wasn't enough of a "boss" (material surrounding the pin) to keep lots of the cases from cracking at the pin. All of this said though, the sound of a 2.7 and smaller motor through a sport exhaust or megaphones is impossible to duplicate with a larger motor. I miss it. Good luck |
Dr Evil |
Feb 15 2011, 05:48 PM
The 2.7 is a fun and cheap motor. I got one, rebuilt it, did not throw the expensive upgrades into it: newer oil pump, oil fed chain tensioners. The upgrades are better, but not necessary. I got a 74, so no thermal reactor BS to deal with. The 74 is a healthy engine to start with. I rebuilt my engine for less than $3k buy educating myself and seeking out experience vs regurgitated hearsay. Another good thing about a 2.7 is that you do not need an oil cooler. It is the biggest you can go without needing one.
kconway |
Feb 15 2011, 06:03 PM
I think I'm going with a 2.4 at this point instead of this one that Ron's hooking me up with...
RiqueMar |
Feb 15 2011, 06:09 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:08 AM |
