Valve adjustments on a 76' 2.7 |
RiqueMar |
Feb 16 2011, 06:34 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Heyguys, I'm looking for this and I've tried a few things on the search function, but I can't seam to find the proper values for the valves on this 2.7, any knowledge for a young dumb rookie?
SLITS |
Feb 16 2011, 06:42 PM
0.004" cold for both.
Cap'n Krusty |
Feb 16 2011, 06:43 PM
Valve clearances for 911 engines with adjustable valve lash are .004". They need to be right on the money, especially for the earlier engines.
The Cap'n |
RiqueMar |
Heyguys, I'm looking for this and I've tried a few things on the search function, but I can't seam to find the proper values for the valves on this 2.7, any knowledge for a young dumb rookie? Think I got it off the bird board....Here ---> Valve Adjustment Can anyone confirm? |
RiqueMar |
Feb 16 2011, 06:45 PM
0.004" cold for both. Valve clearances for 911 engines with adjustable valve lash are .004". They need to be right on the money, especially for the earlier engines. The Cap'n Awesome guys, thanks for the help!I'm glad to see the 'Pro's' are on right now! (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) |
SLITS |
Feb 16 2011, 07:12 PM
make sure you get the tool with spare blades ... makes it much easier (kinda)!
Cap'n Krusty |
Feb 16 2011, 07:33 PM
Wayne's "911 Valve Adjustment Made Easy" shows you the hard way, but that's OK. ALWAYS adjust the valves BEFORE you remove the spark plugs. Too easy for a piece of carbon to be dislodged and fall into the opening for the exhaust valve, making your adjustment way off.
You can use my easy valve adjustment method (which can be found in the Classic Threads forum). Rock one valve all the way open, adjust the opposite valve. Piece o'cake. In the car, you use a starter button, out of the car, you use a 19mm (3/4") box wrench on the crankshaft pulley. The Cap'n |
Downunderman |
Feb 17 2011, 12:56 PM
Senior Member Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
I do it this way.
http://www.pelicanparts.com/techarticles/9...valveadjust.htm I have found it to be more accurate. |
Cap'n Krusty |
Feb 17 2011, 01:09 PM
I do it this way. http://www.pelicanparts.com/techarticles/9...valveadjust.htm I have found it to be more accurate. Sounds like a lot more work (especially with the engine installed in a 911, much less a 914 where access is severely compromised), and I doubt it's more accurate than my technique. The Cap'n |
Lo-Fi Version | Time is now: 17th June 2024 - 12:22 PM |
