JWest Shifter Linkage with Renegade Subie Package |
fat73 |
Feb 16 2011, 09:05 PM
W9R1 Group: Members Posts: 244 Joined: 7-May 05 From: tampa,fl Member No.: 4,043 Region Association: South East States |
Anybody out there using the Renegade Subie conversion also using the JWest Shifter Linkage setup? I already have the Rennshift setup, but continue to have bushing issues causing sloppy shifting apparently because the fabricated shifter bar (necessary to clear the engine) is not exactly right. I figured if I was going to have to adjust the shifter bar (cut it up) again I might want to go with a better setup.
Ed |
SirAndy |
Feb 17 2011, 11:37 AM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I don't see any reason why it shouldn't work as long as your engine is not in the way of the shift rod ...
(IMG:style_emoticons/default/smile.gif) |
Mike Bellis |
Feb 17 2011, 11:39 AM
Even if the engine is in the way, make a new rod the bends around the engine.
Lo-Fi Version | Time is now: 10th June 2024 - 03:28 AM |
