> 914 engine oil breather, Is it really necessary
recko911
post Feb 17 2011, 12:05 AM
Is a oil breather filter really necessary on the engine case.
Replies(1 - 5)
McMark
post Feb 17 2011, 12:34 AM
914 Freak!
Short Answer: Yes
Long Answer: You need to vent your crankcase. And to avoid messes and environmental impacts, you should filter your crankcase ventilation. The best solution is to filter the vapors, drip drain it back into the case, and connect the filtered vapor to the intake so that any missed particles can be burned in combustion.
recko911
post Feb 17 2011, 10:14 AM
QUOTE(McMark @ Feb 16 2011, 10:34 PM) *
Short Answer: Yes
Do you have any pictures of the set u I have dual carbs.
post Feb 17 2011, 11:02 AM
Hummmm!!!
http://www.914world.com/bbs2/index.php?sho...=103161&hl=
Here is a good thread on the subject...I vented back to Filler neck base using CFR Can.....
Good Luck
gothspeed
post Feb 17 2011, 11:41 AM
Definitely vent! Also make sure you use the factory check-valve, it keeps the crankcase from building too much pressure, which will help prevent oil leaks.
ChrisFoley
post Feb 17 2011, 12:09 PM
I am Tangerine Racing
QUOTE(gothspeed @ Feb 17 2011, 12:41 PM) *
Definitely vent! Also make sure you use the factory check-valve...
Only when the factory injection is retained should the stock valve be left intact. We gut the PCV valve on every breather installation, but still use it as a connection point in most cases. The stock valve is a restriction to good ventilation.
- Lo-Fi Version Time is now: 4th July 2025 - 01:04 AM
