> cooling fan, did I screw up?
surfbus66
post Feb 22 2011, 04:57 PM
Took the pulley off of cooling fan to blast and repaint. Just noticed when blasting that there is a small piece of metal pounded into the pulley. Did the factory do this for balancing? If so, did i screw up by not indexing fan and pulley prior to removal? Thanks for your input.
Replies(1 - 6)
bam914
post Feb 22 2011, 05:37 PM
Yes. Plus the pulley will no longer be centered to the fan hub.
detoxcowboy
post Feb 22 2011, 06:49 PM
Region Association: Africa
Jake Raby
post Feb 22 2011, 06:53 PM
Engine Surgeon
Re-centering will be a real bitch.. Unless you have access to a balancer or make yourself a centering tool, it won't be happenning. This is critical to dynamic balance and even keeping the alternator belt on the engine.
surfbus66
post Feb 22 2011, 06:59 PM
QUOTE(Jake Raby @ Feb 22 2011, 04:53 PM) *
Is getting it centered more of the issue than where the weight is placed, or do both need to be concidered?
Jake Raby
post Feb 22 2011, 07:20 PM
Engine Surgeon
Both.. If its not centered it can't be balanced. I have seen people remove these and reinstall them only to imbalance the engine 40 grams.
surfbus66
post Feb 23 2011, 05:21 AM
thanks for your help.
- Lo-Fi Version Time is now: 8th December 2025 - 02:22 AM
