Quick Points Questions, Dropping points for electronic |
avidfanjpl |
Feb 26 2011, 09:48 PM
914 Hemophiliac Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
OK, saw this a few times in the last 2 years, but does anyone know if there is a best in class points replacement kit easily available?
And how do you replace the points with the new electronics? I am done with points. Need to skip the adjustment thing for good. I will take my chances and keep a set of points in the car just in case, but what is the best way to get this decided and done? Thanks! John avidfanjpl |
turnaround89 |
Feb 26 2011, 10:55 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Pertronix II or Pertronix I are pretty common to use, they come with everything you need to change from points to electronic. Just make sure you get the correct one for the dizzy you have and don't wire it backwards(if you do wire it backwards you'll end up with a 120 dollar paperweight)
Supposedly the Pertronix II can be wired backwards and not fry, but im not gonna be the one to take the chance of testing that idea. |
SLITS |
Feb 27 2011, 07:52 AM
Newbie question. Can you use a petronix with a D-Jet? What do you do for the FI triigger points? (IMG:style_emoticons/default/confused24.gif) Trigger points are seperate from the ignition points. Yes, it will work just fine. |
jt914-6 |
Feb 27 2011, 08:02 AM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Pertronix II or Pertronix I are pretty common to use, they come with everything you need to change from points to electronic. Just make sure you get the correct one for the dizzy you have and don't wire it backwards(if you do wire it backwards you'll end up with a 120 dollar paperweight) Supposedly the Pertronix II can be wired backwards and not fry, but im not gonna be the one to take the chance of testing that idea. Pertonix II is only available for the six the last time I checked...... |
SLITS |
Feb 27 2011, 08:10 AM
Petronix Hall Effect
Compufire Hall Effect Crane XR700 Optical And I sure there are some unknown Chinese brands out there too! |
76-914 |
Feb 27 2011, 08:35 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I've run Pertronix for 8 yrs in one car and 2 in another and love 'em. One catch is you can't leave the ign switch in the on position when the car isn't running. They'll fry.
turnaround89 |
Feb 27 2011, 07:46 PM
The pertronix II can be run in a 4, i am currently doing that...bought mine from jcwhitney.com....they had the best price plus free shipping at the time.
However, im not running a stock coil so maybe thats why i can run it in my 4 You can run one in a bosch 009 or 050 dizzy Pertronix II at jcwhitney |
jt914-6 |
Feb 27 2011, 08:32 PM
The pertronix II can be run in a 4, i am currently doing that...bought mine from jcwhitney.com....they had the best price plus free shipping at the time. However, im not running a stock coil so maybe thats why i can run it in my 4 You can run one in a bosch 009 or 050 dizzy Pertronix II at jcwhitney That's nice to know...the Ignitor II is a better unit than the orignal..... (IMG:style_emoticons/default/beerchug.gif) |
sww914 |
Feb 27 2011, 09:37 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
Pertronix is the easiest thing ever.
avidfanjpl |
Feb 27 2011, 10:03 PM
Thanks all! Pertronix it will be
Do I disconnect the coil if I want to leave the key on for something? John |
Lo-Fi Version | Time is now: 6th June 2024 - 03:05 PM |
