broomhandle |
Member ![]() ![]() Group: Members Posts: 290 Joined: 26-June 09 From: Half Moon Bay, CA Member No.: 10,512 Region Association: Northern California ![]() |
I was given a 73 blower motor for my '70. they look very different. were there changes at all?
or has anybody re-built the blower motor? its just a electric motor. i need a defroster and a heater!!! |
Kirmizi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None ![]() |
How different?
I thought they were the same, but with different mounting locations. Mike |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
Don't know the changeover dates but an "early" blower fan is a 2 outlet fan mounted on the fan housing about in the middle and the "late" fan is a 1 outlet fan mounted under the relay board.
broomhandle |
Don't know the changeover dates but an "early" blower fan is a 2 outlet fan mounted on the fan housing about in the middle and the "late" fan is a 1 outlet fan mounted under the relay board. yes, the plugs are different. is there any way to convert the 70 to a 73 blower? or not even worth it. just fix my broken one? does anybody know what the main problems are for a blower motor? i am assuming its the motor.... who has fixed one? also, does the defroster use that same blower motor? just different paths in the cab? |
type47 |
The only 2 things I have found that goes bad with these old motors is the brushes, which I never found replacements for, it was easier to find a "new" (to me) motor than the brushes; and the "bearings" for the armature which would rust up or dry up.
Lo-Fi Version | Time is now: 1st July 2025 - 07:42 AM |
