Is it legal?, What size gun does one use?? |
Razorbobsr |
Mar 11 2011, 03:59 PM
Member Group: Members Posts: 282 Joined: 6-June 10 From: Terre Haute Ind Member No.: 11,813 Region Association: Upper MidWest |
Engine runs fine at 900 RPMs, cleaned jets, changed plugs, changed bad NEW plug, changed plug wires. Under driving loads miss-fires!!!!!!!!!!!!!!! I can feel 1 cyl hitting and missing under normal aceleration and WOT engine pulls like a horse. Does anyone know of a 914 guy, in or near Terre Haute Ind?????? I am at my wits end, its simple, I know it is but I cant find it! After this prob sense last spring/summer/fall. 2L eng, rebuilt, driven 1500 miles to home without a prob. Bob.......... Time to start drinking
OK, done drinking for the week! Could I have a coil failing? Engine will hold 4K smoothly in driveway, 900 idle.... but engine falls down under a load. Do have Seafome in tank, gas has been in tank sense last summer but I had this prob before I gassed it up. Bob |
Woody |
Mar 11 2011, 05:21 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Sounds like plugged idle jets. Blow em out again. Then take a can of carb cleaner and stick the little red twiggy thing into the hole for the idle jet and give it a few good squirts.
d914 |
Mar 11 2011, 06:07 PM
Advanced Member Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
Gas tank might be dirty and cause a re-occurring problem with the jets,, Make sure you have good filter before the carbs..
stugray |
Mar 11 2011, 06:46 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
My Ghia had a similar problem.
Turned out that the fuel tank was rusting and clogged the fuel line. Took tank out, blew lines out ran better than ever afterwards. However if yours runs good at WOT, then it is probably not starving. Stu |
Elliot Cannon |
Mar 12 2011, 12:32 AM
Idle jets... Clean everything from the carbs to the tank. Install good fuel filter. Drive the piss out of it. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/driving.gif)
Razorbobsr |
Mar 12 2011, 06:57 AM
Razorbobsr |
Mar 12 2011, 06:58 AM
Razorbobsr |
Mar 12 2011, 07:04 AM
My Ghia had a similar problem. Turned out that the fuel tank was rusting and clogged the fuel line. Took tank out, blew lines out ran better than ever afterwards. However if yours runs good at WOT, then it is probably not starving. Stu |
Lo-Fi Version | Time is now: 7th June 2024 - 02:08 AM |
