Targa pad, what screws hold it on? |
patssle |
Mar 12 2011, 01:53 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I've removed everything from my targa, except the front pad that fits up against the seal. I can't find the screws in the hole, there's too much "stuffing" and prodding around can't get the screwdriver in the head of the screw.
What type of screws are holding it on? Hex, flat, regular? |
mepstein |
Mar 12 2011, 02:04 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I've removed everything from my targa, except the front pad that fits up against the seal. I can't find the screws in the hole, there's too much "stuffing" and prodding around can't get the screwdriver in the head of the screw. What type of screws are holding it on? Hex, flat, regular? Small phillips. Just like the other pads and trim. |
montoya 73 2.0 |
Mar 12 2011, 05:25 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
I had the same problem when I was removing mine. I couldn't find the screw head so after a few days of fish around, I just ripped the damn stuffing and material off! Then I could see the small phillips head had been mounted at an angle. Good luck!
patssle |
Mar 12 2011, 06:47 PM
I had the same problem when I was removing mine. I couldn't find the screw head so after a few days of fish around, I just ripped the damn stuffing and material off! Then I could see the small phillips head had been mounted at an angle. Good luck! I've thought about it, especially since it's a bit torn underneath at one spot. Is the pad really necessary? I know it pushes up against the seal, but I'm not worried about water, this car doesn't see the rain. Or does it help hold the seal on? |
montoya 73 2.0 |
Mar 12 2011, 07:54 PM
I never put another back on for that same reason. I kind of like it without!
AZ914 |
Mar 12 2011, 09:46 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
I just went through this. If you can pluck out some of the 'stuffing' with some small needle-nose pliers then just sting your screwdriver in until it seats. It was a pain, don't forget the vertical screws underneath the pad.
My pad was so beat up that I ended up going without. I ran perlon on the inside bottom of the targa bar and used some edging on the front. It came out pretty good! The only drawback is not the latches are exposed so you need to be sure they seat properly when using them. |
Lo-Fi Version | Time is now: 11th June 2024 - 08:33 AM |
