5-lug Conversion from 72 911T, Questions on Rear Hub Use |
Spoke |
Mar 16 2011, 10:40 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I'm picking up this suspension from a 72 911T for my 5-lug conversion.
For the front, I need just the uprights/hubs/rotors/calipers. For the rear, I would like to use at least the hub. I've heard the spline is different than the 914 half shaft. What do I have to do to use the hub? What about the vented rotor? The rear calipers are gone. I can use spacers on my existing 914 calipers. Is it worth it to use vented rotors on the rear. If I decide to stay with solid rotor, do I order 914/6 rotors? Thanks in advance. Attached image(s) |
Andyrew |
Mar 16 2011, 10:58 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
You probably have to machine spacers for the rear calipers, but be sure to use longer, proper grade, bolts. This is what I run on the rear of my car with vented rotors. Works great.
Eric_Shea |
Mar 16 2011, 01:07 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE but be sure to use longer, proper grade, bolts. This is what I run on the rear of my car with vented rotors. Works great. Where did you get the fasteners? QUOTE What do I have to do to use the hub? Ahhh. you got the bargin suspension. Good work. Someone was asking about it but... You have all of the parts... all you need are axles (and maybe tranny flanges): http://www.914world.com/bbs2/index.php?showtopic=91963 QUOTE If I decide to stay with solid rotor, do I order 914/6 rotors? Yes... then have them milled by 4mm in total diameter. With the price of -6 rotors right now, it's cheaper to buy -4 rotors and have them machined to 5x130 (you would have to machine both if you stuck with stock -4 calipers). |
Andyrew |
Mar 16 2011, 01:11 PM
Eric, They came on my calipers. Bought them as a used setup.
Spoke |
Mar 16 2011, 09:02 PM
Eric_Shea |
Mar 16 2011, 09:07 PM
Not sure why you would want a 914 CV when you have those bad boys staring you in the face... (IMG:style_emoticons/default/huh.gif)
The cheapest way to go 5-lug is to sell all that stuff to Enrique (I see him lurking here) and get some modififed -4 hubs and pocket the change. The best way would be to keep that stuff and grab some Sway-a-Way axles for $308.00 and see if the guy you bought it all from still has the tranny flanges. Bullet - Proof. If you sell the arms (front and rear) and various other goodies, it could help pay for the axles. |
Spoke |
Mar 17 2011, 01:49 PM
Not sure why you would want a 914 CV when you have those bad boys staring you in the face... (IMG:style_emoticons/default/huh.gif) Well, I'm trying to 5-lug with as low of initial cost as possible. The cost so far is not insignificant but also not that great: Got the wheels ($400), need tires ($500), 19mm MC ($200), F&R suspension ($150), Probably new front inserts ($150), probably rebuild 4 calipers ($25 each), rear caliper widening kit for vented rotor ($225), Maybe new rotors ($300). I would like to start with the 914 CV, then later move to the 911 CV and new half-shafts with 911 trans flanges. |
jmill |
Mar 17 2011, 06:45 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Most guys don't want to give up just the flanges. They'll want to sell you the entire tranny. I ended up getting a pair of flanges at DC Auto for about $70.
I'm saving up for the axles to do the rears up like Eric's how to thread. |
PRS914-6 |
Mar 17 2011, 06:53 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
I'm going by memory so check first. That looks like older non "hubcentric" flanges. If I recall they don't need the 5mm spacers (verify)
I think they went to the larger bearing when they started making hubcentric flanges. Again, that's what my beat-up brain recalls |
Eric_Shea |
Mar 17 2011, 09:42 PM
QUOTE If I recall they don't need the 5mm spacers (verify) Correct o-wise-one (IMG:style_emoticons/default/locust.gif) Those just slide right in. Probably the same part number as a 914-6 hub. 1974 was a new year, new deal. Taller/Wider bearing (same I.D.) and hub-centric hubs. |
Gary |
Mar 17 2011, 10:00 PM
Senior Member Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
You can use sportomatic coarse spline tranny flanges. I may have a spare set. They're the 100mm diameter to match the 911 CVs and are longer than manual flanges. I have this setup and it lets you use the 911 half shafts (still available).
G |
sixnotfour |
Mar 17 2011, 10:02 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Doent fix the CSOB's stub problem. Send me the axles,stubs,flanges and Ill send you some drilled and studded -4 hubs and drilled rotors in exchange.
Lo-Fi Version | Time is now: 7th June 2024 - 09:46 AM |
