mounting engine stand adapter to engine, how does this attach? |
hot_shoe914 |
Mar 20 2011, 08:59 AM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
SLITS |
Mar 20 2011, 09:27 AM
The two large holes fit over the transmission mounting studs.
The four smaller holes are to mount the arms of the engine stand plate. I threaded mine for 3/8" bolts to attach the arms of the engine stand to the adapter. The notch with the hole (at bottom of your pic) is to mount the flywheel lock. Sometimes it takes some doing to arrange the arms of the engine stand to fit semi-correctly. Oh, I have two of the adapters. I would have edited the image, but I don't have photoslop on this 'puter. |
J P Stein |
Mar 20 2011, 09:34 AM
I attach the ring in the position you have it.....to the oil pump side of the case.
Studs with spacers to get the threads. How you attach the ring to the engine mount is your problem....not trying to be nasty. The proper tool takes care of that.(see pic) You may have to do some welding. |
hot_shoe914 |
Mar 20 2011, 09:36 AM
The two large holes fit over the transmission mounting studs. The four smaller holes are to mount the arms of the engine stand plate. I threaded mine for 3/8" bolts to attach the arms of the engine stand to the adapter. The notch with the hole (at bottom of your pic) is to mount the flywheel lock. Sometimes it takes some doing to arrange the arms of the engine stand to fit semi-correctly. Oh, I have two of the adapters. I would have edited the image, but I don't have photoslop on this 'puter. Thanks slits. Does the flat side go to the engine? |
J P Stein |
Mar 20 2011, 09:37 AM
Studs with spacers to get the threads. How you attach the ring to the engine mount is your problem....not trying to be nasty. The proper tool takes care of that.(see pic) You may have to do some welding. Attached thumbnail(s) |
SLITS |
Mar 20 2011, 09:42 AM
The two large holes fit over the transmission mounting studs. The four smaller holes are to mount the arms of the engine stand plate. I threaded mine for 3/8" bolts to attach the arms of the engine stand to the adapter. The notch with the hole (at bottom of your pic) is to mount the flywheel lock. Sometimes it takes some doing to arrange the arms of the engine stand to fit semi-correctly. Oh, I have two of the adapters. I would have edited the image, but I don't have photoslop on this 'puter. Thanks slits. Does the flat side go to the engine? There is a relief that fits the case machined/cast into one side of the adapter (beveled side). That goes against the case to accommodate the lip on the case, so the answer is NO! I mount the adapter to the opposite side of what you have shown. I love being contrary to JP. |
J P Stein |
Mar 20 2011, 09:52 AM
I mount the adapter to the opposite side of what you have shown. I love being contrary to JP. Knock yourself out. (IMG:style_emoticons/default/biggrin.gif) I'd love to see a pic of how you assemble the motor. |
SLITS |
Mar 20 2011, 09:58 AM
I mount the adapter to the opposite side of what you have shown. I love being contrary to JP. Knock yourself out. (IMG:style_emoticons/default/biggrin.gif) I'd love to see a pic of how you assemble the motor. Ya got me ... haven't split the case on a Six as yet ... just P&Cs & head work. I'll get around to splitting one on the next engine (bad #5 rod) and I will find out that I can't do it JP ... (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/biggrin.gif) |
iamchappy |
Mar 20 2011, 10:34 AM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
I have mine on like this right now, and I've had it on the other side before.I used a 1/2" socket to snug up the nut on the stud, In the past i have backed out the stud and attached it with a bolt, since it is really only hanging off of the studs i do it this way now.
Lo-Fi Version | Time is now: 8th June 2024 - 02:09 AM |
