Output shafts, re-installing |
Randal |
Mar 22 2011, 04:47 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Tightening and torquing the output shafts on a 901. I guess I'm a bit worried about over torquing the bolts that hold on the output shaft. After stripping one of the flange holes I'm worried that I could be doing something wrong and stripping this bolt would mean tearing the transmission down. Once bit I guess. For some reason they just keep on tightening and won't move (using the old type torque wrench with a movable lb indicator) up to 60lbs. So is there any way that something could be wrong with such a simple installation. I understand the torque setting to be 60ft lbs Thanks. |
J P Stein |
Mar 22 2011, 05:36 PM
Are you speaking of the *stretch bolts* in the center of the output flanges? If so, you'd better stop twisting and find out what the torque is supposed to be. I can't recall & I've sold all my technical manuals to MikeK.
Randal |
Mar 23 2011, 10:37 AM
Are you speaking of the *stretch bolts* in the center of the output flanges? If so, you'd better stop twisting and find out what the torque is supposed to be. I can't recall & I've sold all my technical manuals to MikeK. Woo, did I get some bad information. The Hayes manual says 25-29 lb f ft Umm....maybe I should change those bolts that I stretched to 50 lb f ft? |
ChrisFoley |
Mar 23 2011, 11:01 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Umm....maybe I should change those bolts that I stretched to 50 lb f ft? (IMG:style_emoticons/default/w00t.gif) Signs point to YES |
J P Stein |
Mar 23 2011, 11:12 AM
Them bolts probably wouldn't give you any trouble......untill the worst possible time you can imagine. (IMG:style_emoticons/default/blink.gif)
Randal |
Mar 23 2011, 11:41 AM
Umm....maybe I should change those bolts that I stretched to 50 lb f ft? (IMG:style_emoticons/default/w00t.gif) Signs point to YES Who sells them? |
Randal |
Mar 23 2011, 11:43 AM
Them bolts probably wouldn't give you any trouble......untill the worst possible time you can imagine. (IMG:style_emoticons/default/blink.gif) Like around a high speed corner in a hill climb - you lose power to one side and take a real ride.... Now I'm going to change them for sure! |
J P Stein |
Mar 23 2011, 11:51 AM
Brit has a bunch of them from my old trans spares stash, IIRC.
Randal |
Apr 1 2011, 04:40 PM
Randal |
Apr 1 2011, 10:03 PM
Just a heads up.
If you are going to bigger 944 turbo CV's then you need longer bolts, like 55mm. As Tom Amon said, make sure the bolts come out at least 5-8mm on the inside. That way you are sure that you are engaging all the thread in the flanges, otherwise you will be very disappointed. (IMG:style_emoticons/default/icon8.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 03:09 AM |
