Slightly Bent A Arm, Opinions on Fix or Replace |
andys |
Mar 23 2011, 04:19 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
When doing preliminary adjustments to my '89 Carrera front suspension (upgrade), I noticed the top of the left strut was positioned slightly arears compared to the right (after setting caster). Close measuring revealed that the A arm is slightly bent: Looking at the left suspension from the side of the car, the end of the A arm where the ball joint attaches appears slightly bent. It is rotated 4 degrees clockwise, and pushed back 1/4". The bend seems to be where the arm necks down just inward of the ball joint mount.
So fix or repair? I have complete machine shop capability to make whatever fixtures or nests necessary accomodate a hydraulic press. The A arm(s) came off a car with 59K miles, so the bushings are in good shape and worth the time investment to save it. I think the *fix it* risk is low, but would like some opinions from perhaps someone that's BTDT. If *replace* is necessary, I need a late left side A arm with *good* bushings (and not bent :-))....Anyone? Thanks, Andys |
VaccaRabite |
Mar 23 2011, 04:22 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Replace with one that is not bent.
JRust |
Mar 23 2011, 04:24 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
McMark |
Mar 23 2011, 06:13 PM
Anyone who's been into 914s long enough has a couple of arms kicking around the garage. Bruce Stone is down there and he's parted out more than a few cars. |
Eric_Shea |
Mar 23 2011, 06:17 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE Anyone who's been into 914s long enough has a couple of arms kicking around the garage. QUOTE my '89 Carrera front suspension |
J P Stein |
Mar 23 2011, 08:28 PM
Replace it. I've seen a 911 A-arm break in that spot. Just getting it on a trailer was ugly.
r_towle |
Mar 23 2011, 08:45 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Sounds a bit complex to fix perfectly and you really want it right.
I would suggest you call Jim at EASY auto parts up near SFC and get him to ship you another one. rich |
jd74914 |
Mar 23 2011, 10:08 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Make a new pair to go with your homemade rear arms Andy. (IMG:style_emoticons/default/hide.gif)
andys |
Mar 24 2011, 10:05 AM
Replace it. I've seen a 911 A-arm break in that spot. Just getting it on a trailer was ugly. I figure that's the logical place for one to break. I layed it out with straight edges, 1-2-3 blocks, and a precision digital angle finder: 1/4" arears and rotated 4*. I realize that in itself doesn't remove any potential risk, but it is only *slightly* bent. I've seen A arms cut and extended in exactly this spot on track cars with big tires, though in the back of my mind that always seemed a bit risky. Andys |
andys |
Mar 24 2011, 10:10 AM
Jim, You remember those, huh? Good memory! Andys |
Cap'n Krusty |
Mar 24 2011, 10:49 AM
Go with a straight one. Straightening yours would put stress on top of stress, not a good thing, IMO.
Lo-Fi Version | Time is now: 1st June 2024 - 11:38 AM |
