Engine Case Cleaning, With an Assembled Engine (What is The Best Way to Clean the Case? |
914four |
Mar 27 2011, 06:10 PM
Senior Member Group: Members Posts: 510 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States |
I'm having some trouble cleaning the engine case and would like to know the best way to clean the engine case without disassembling the engine. I have used degreaser with some success but it is not as clean as some engines I have seen on the forum. As you can see in the picture I have cleaned the front part of the case only. Is there a better way?
luskesq |
Mar 27 2011, 11:11 PM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
I'm having some trouble cleaning the engine case and would like to know the best way to clean the engine case without disassembling the engine. I have used degreaser with some success but it is not as clean as some engines I have seen on the forum. As you can see in the picture I have cleaned the front part of the case only. Is there a better way? Oven cleaner works pretty good. Been a while since I used it and I don't recall if it affects paint. Does take care of the baked on grime however. Keith |
Tom_T |
Mar 28 2011, 12:10 AM
Oven cleaner is lye & other harsh stuff, which will eat into the aluminum & magnesium alloys on the engine & transaxle cases, heads, etc. - in addition to stripping the paint off the engine tins, etc. Save it for cleaning your porcelainized oven (note that they usually warn to keep it off the stainless steel & other painted parts of your fancy ovens, but who read directions anymore).
WD40 can work well if you let it sit for awhile, but may take some time & several tries. McMark & others have soda blasted cases when out of the car & properly protected & sealed, or completely disassembled - but then you need to get all the soda out in either case. |
r_towle |
Mar 28 2011, 08:26 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I use more citric based cleaners...super purple and those sorts.
I think Simply green also. It takes time, a good cleaner and brushes....just like you have. Get a better cleaning product that will remove mor grease. Rich |
PanelBilly |
Mar 28 2011, 08:34 AM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
HF was some cheep wire tooth brushes that i used to touch up some spots. Then I vacumed the dust out
Scott S |
Mar 28 2011, 09:34 AM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
There are these sets of three brushes I see for sale at nealry every FLAPS. Two wire and one stiff plastic. I went through probably 20 sets cleaning my current motor - and it was pretty clean to begin with. They are about twice the size of a tooth brush. I used them first with simple green and an air jet fitting on the compressor. Then used new clean sets after the motor was dry. I was really pleased with the results. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:00 PM |
