Maine914 |
Member ![]() ![]() Group: Members Posts: 99 Joined: 30-January 03 From: Maine Member No.: 215 ![]() |
It hit 50 degrees in Maine, so I started in on the car. Put the
carbs back in, and she fired right up. Yahoo! Of course, I couldn't drive it anywhere because it has no brakes. When I removed the leaky 17mm master cylinder, the brake line to the front driver's side broke. Any recommnedations on a replacement: OEM, stainless steel, etc. Thanks |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(Maine914 @ Apr 13 2003, 09:50 AM) ...the brake line to the front driver's side broke. Any recommnedations on a replacement: OEM, stainless steel, etc. the hard line ? no-brainer - just about every FLAPS has the appropriate EURO METRIC 1,0mm x 10,0mm 'bubble' flare hardline. measure the length you need, get the appropriate replacement line. and a tubing bender and appropriate flare-fitting wrenches, if you don't have them already. if it's the flex line, that's a fire storm. "everybody" knows someone who had a failure in a steel-braided flex hose 30 years ago. the braided-steel-sheathed Teflon hoses may or may not provide a performance difference. opinions vary on that, too. once upon a time all braided-steel Teflon flex hoses were marked 'offroad use' or 'racing use' only. that was then. today there are DOT-rated flex hoses (with rubber sheaths so if you're doing it for the look, don't bother, they don't look that much different...). factory flex hoses are 'the safe' choice although they too have a failure mode (but it'll probably take a lot of years for it to manifest...). i don't think i'd run a non-DOT hose now that the DOT-rated stuff is available -- even though i've done exactly that before they were and not (yet - some would say...) experienced a problem. |
Lo-Fi Version | Time is now: 6th July 2025 - 10:19 AM |
