FS: Spring cleaning parts, Misc. parts, interior and exterior |
Cheapsnake |
Apr 1 2011, 07:37 PM
Member Group: Members Posts: 419 Joined: 15-November 07 From: Door County, WI Member No.: 8,341 |
email ffr2776@sbcglobal.net for more info or pics on any of this stuff
ALL PRICES INCLUDE SHIPPING: Ashtrays, $12 Sideshift shifter, $35 Rubber shift boot, $10 Early Seat belt set, rusty mounts, but useable, $25 Steering column assemblies w/key, one '71, one '73, one 74, your choice, $75 Sail panel trim, side pieces, some scratches but useable, $40 Plastic plugs for front sheet metal, about 10, $8 Front bumper top, two studs replaced, a bit dimply but surface is VG, $125 Targa tops, one from a '71, one from a '73, no front latches, $90 Late window regulators, D & P, $30 each Early P side window regulator, $30 Rear windows, non heated, $55 Lower dash pads, late, $50 Brake proportioning valve, cleaned and repainted, $20 Fuel level sender, w/gasket, checked good, $60 Headlight switch, $50 Foglight switch $40 Emergency flasher switch, $40 Cigarette lighter, including socket, $20 Rain tray, all mounting holes intact, small repaired crack on interior, almost invisible, $65 Starter motor, cranks good, cleaned and painted, $50 1.8 Flywheel, clutch and pressure plate, used but useable, $90 Black interior trim pieces, name your piece, $12 Parts added:[b] Rain trays, all mounting holes are crack-free, small <1" crack on interior has been repaired with epoxy and is almost invisible. $65, shipped. Drain tubes are crack-free, take them with a rain tray for $15, $25 on their own. 2.0 Distributor with new points and wires, cap looks new, but not sure. 039 905 205 BA. $110 shipped. Relay board cover. Yes, it's been cracked like 90% of them but I've been rehabbing them by bonding aluminum washers to both sides of the bolt hole. Looks factory and stronger than original. $18 shipped. Steering racks, they're tight. $100 shipped |
cpfoster |
Apr 1 2011, 09:15 PM
Newbie Group: Members Posts: 9 Joined: 11-May 10 From: Washington, DC Member No.: 11,718 Region Association: None |
email ffr2776@sbcglobal.net for more info or pics on any of this stuff ALL PRICES INCLUDE SHIPPING: Steering wheel w/horn pad, the bare plastic type, GC, $70 Ashtrays, $12 Sideshift shifter, $35 Rubber shift boot, $10 Heater dash controls, w/good trim ring, $35 Early Seat belt set, rusty mounts, but useable, $25 Steering column assemblies w/key, one '71, one '73, one 74, your choice, $75 Turn signal assembly form a '73, $25 Sail panel trim, side pieces, some scratches but useable, $40 Plastic plugs for front sheet metal, about 10, $8 Front bumper top, two studs replaced, a bit dimply but surface is VG, $125 Targa tops, one from a '71, one from a '73, no front latches, $90 Late window regulators, D & P, $30 each Early P side window regulator, $30 Rear windows, non heated, $55 Lower dash pads, late, $50 Rebuilt pedal assemblies, blasted, dipped, double coated Rust-Oleum (brushed, not rattle-canned), new bronze bushings, $125 Late Gauge cluster, cleaned and repainted, all gauges work, $100 Brake proportioning valve, cleaned and repainted, $20 Fresh air blower and housing, $100 Fuel level sender, w/gasket, checked good, $60 Headlight switch, $50 Foglight switch $40 Emergency flasher switch, $40 Cigarette lighter, including socket, $20 Rain tray, all mounting holes intact, small repaired crack on interior, almost invisible, $65 Original shift knobs, some crazing on the crest, $12 Starter motor, cranks good, cleaned and painted, $50 1.8 Flywheel, clutch and pressure plate, used but useable, $90 Black interior trim pieces, name your piece, $12 Lots of other stuff, just ask. PM sent on steering wheel, shifter knob |
Cheapsnake |
Apr 2 2011, 05:51 AM
casey944 |
Apr 2 2011, 08:42 AM
Member Group: Members Posts: 139 Joined: 10-August 09 From: nova Member No.: 10,654 Region Association: MidAtlantic Region |
Interested in the bumper top. could you please email me a picture?
m030marketing@gmail.com |
OpusX67 |
Apr 2 2011, 06:05 PM
Newbie Group: Members Posts: 4 Joined: 24-March 10 From: Florida Member No.: 11,500 Region Association: South East States |
Interested in the sail pieces. Please send pics to OpusX67ATaol.com
Cheapsnake |
Apr 7 2011, 08:58 AM
New parts added to original post. Oh yeah, and a shameless (IMG:style_emoticons/default/icon_bump.gif) .
OU8AVW |
Apr 7 2011, 12:18 PM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
Interested in the 71 targa top. Please get me some info and/or pics.
mike@southboundcruisingservices.com for faster response... Thanks |
Lo-Fi Version | Time is now: 8th June 2024 - 01:41 PM |
