fuel line crimper, who, where, what and how (much)? |
brp986s |
Apr 3 2011, 12:49 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
I have a motronic system with lots of crimped fuel line connections that I'd like to replace. I really don't want to cut these off and replace with flaps hose clamps. It's my experience that the exposed ends start to get attacked by ozone in a hot engine bay and are good for a few years only. 'Course, I'm referring to these:
The questions are what and how. I poked around and found this doohickey which might do the job. Or not, I don't know. Crimping tool: Or maybe there are other ways to get a high quality result. Anyone know? By the way, many of these lines incorporate metal tubes and brackets which are far too expensive to buy from Porsche or attempt to reproduce. |
IronHillRestorations |
Apr 3 2011, 12:53 PM
I. I. R. C. Group: Members Posts: 6,726 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You might try a shop that fabricates hydraulic lines.
brp986s |
Apr 3 2011, 04:59 PM
You might try a shop that fabricates hydraulic lines. Are there places that do metric lines? If it were a couple separate lines it might be feasible for a shop to make them, but in this case there are a number of them that need to be made as an integrated system with proper orientations and so forth. Basically, you have to bring them the entire motronic system with intakes, fuel rails...the whole enchilada and let them have at it. That has me a little worried. So, I'd like to know if crimping these things is DIY. |
Krank |
Apr 3 2011, 09:18 PM
Member Group: Members Posts: 140 Joined: 11-October 09 From: Winnipeg, MB Member No.: 10,922 Region Association: Canada |
There should be some hydraulic hose shop in your area to do those lines. By the looks of them they are light duty DIN fittings (I could be wrong). If you bring them the hoses complete, they should be able to get the phasing of the fittings to match. If you do find a system to DIY, remember, hose and fitting must match (be compatible with) each other, get the crimp spec of the finished crimp to check your work.
Lo-Fi Version | Time is now: 4th June 2024 - 06:37 PM |
