Fuel delivery issue, Issue solved. Thanks DD |
poorsche914 |
Apr 8 2011, 08:16 PM
T4 Supercharged Group: Members Posts: 3,091 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
When I originally started sorting things out with the FI system on my LE, the fuel pump had a jumper hooked to the coil to run. I removed this and the car starts and runs fine - for a few minutes. A couple times when I ran it down the road a half mile or so and then headed back, the car would hesitate and die about half way back. The first time it did this, it started up after a minute or so and I drove on home. Tonight when the same thing happened, I attached the jumper wire from the fuel pump to the coil and it started up and made it back to the house fine. I even drove it beyond the house about half a mile and back. But when I turned the key off, it kept on running. Had to pull the jumper wire to stop the pump.
Where should I begin troubleshooting this? I would rather get it working properly without the jumper wire. Thanks. (IMG:style_emoticons/default/driving.gif) |
SirAndy |
Apr 8 2011, 08:19 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
When I originally started sorting things out with the FI system on my LE, the fuel pump had a jumper hooked to the coil to run. I removed this and the car starts and runs fine - for a few minutes. A couple times when I ran it down the road a half mile or so and then headed back, the car would hesitate and die about half way back. The first time it did this, it started up after a minute or so and I drove on home. Tonight when the same thing happened, I attached the jumper wire from the fuel pump to the coil and it started up and made it back to the house fine. I even drove it beyond the house about half a mile and back. But when I turned the key off, it kept on running. Had to pull the jumper wire to stop the pump. Where should I begin troubleshooting this? I would rather get it working properly without the jumper wire. Check the fuel pump relay on the relay board. Make sure the contacts are not corroded and make sure it fits tight. If it fits lose, you can carefully pry the prongs a bit to give it a better fit. I would also try to replace it with a other known to be good relay, like one of the headlight relays. (IMG:style_emoticons/default/bye1.gif) |
poorsche914 |
Apr 8 2011, 08:43 PM
Thank you, Andy. I should have thought of that as I replaced my old relay board with a "nicer" one that included relays. Never checked each relay, though.
Dave_Darling |
Apr 8 2011, 09:33 PM
poorsche914 |
Apr 8 2011, 09:52 PM
poorsche914 |
Apr 10 2011, 05:05 PM
There's a fuel pump flowchart on Brad Anders' D-jet page. http://members.rennlist.com/pbanders --DD Flowchart was just what I needed. Came up with a faulty wire in the harness. I nabbed a like-new Bowlsby rebuilt harness from a seller here (IMG:style_emoticons/default/piratenanner.gif) Should have it around mid week or so. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 02:42 AM |
