Headlight removal? |
Cool914 |
Apr 12 2011, 10:15 PM
Member Group: Members Posts: 98 Joined: 25-January 11 From: Ontario Member No.: 12,627 Region Association: Canada |
First, hi everyone. Been lurking here for awhile and doing lots of excellent research, a real wealth of knowledge. I will post the full story of my most excellent cool Canadian adventures (rust mining) in awhile, for now I am busy just stripping my new and first 914 and trying to figure out how to remove the headlight motor.
I have the headlight assembly removed and now trying to get the motor out, took the nut off but the arm does not seem to want to pull away from the motor. I have read the technical article on adjust the headlight and it says "pry" the arm off the motor spindle. Does it need a good prying? i tried but it doesn't seem to budge, just want to make sure I dont need to spin the arm off the spindle or anything. Does it just pull out away from the motor when the nut is off? thanks Attached image(s) |
rick 918-S |
Apr 12 2011, 10:40 PM
Hey nice rack! -Celette Group: Members Posts: 20,471 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
(IMG:style_emoticons/default/welcome.png) Ya, the arm is on a splined shaft. Remove the nut and gently pry the arm loose.
Delphi is a cool color! (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
SirAndy |
Apr 12 2011, 10:53 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Does it just pull out away from the motor when the nut is off? Yepp, it does ... (IMG:style_emoticons/default/welcome.png) |
Cool914 |
Apr 16 2011, 08:39 PM
Does it just pull out away from the motor when the nut is off? Yepp, it does ... (IMG:style_emoticons/default/welcome.png) Thanks guys, screwdriver popped them right off. Now how do I remove the headlight motor from the wiring harness? How do the wires come out of that little rectangular plastic thing (top left of picture)? It doesnt seem like it splits so I assume the wires pull off of one side? |
Mike Bellis |
Apr 16 2011, 08:50 PM
They just pull out.
Lo-Fi Version | Time is now: 1st June 2024 - 05:09 AM |
