Fuch's and Tires - Expert Opinions Requried!, Added Pictures of Mounted Tires and Test Fit |
Larouex |
Apr 13 2011, 09:24 AM
Larouex Group: Members Posts: 144 Joined: 22-July 08 From: Larouex@gmail.com Member No.: 9,339 Region Association: Pacific Northwest |
I have started to fit my new flares. I have Fuch's all around, 16x8 on the back and 16x7 on the front. I have been to 3 tires shops here in Seattle and I am frustrated as no one seems to be able give advice unless they match to a car year and model.
What do you all recommend? I want a lower profile, a flat to receding sidewall and good looks. Here are some project shots... Phase 3 Phase 3 - 2 TIA! Larouex |
Bruce Hinds |
Apr 13 2011, 09:33 AM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
links don't work.
TheCabinetmaker |
Apr 13 2011, 09:39 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Face book??????
mepstein |
Apr 13 2011, 10:25 AM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Common width for those wheels and a flared 914 is 205 & 225 front and rear. You might want to decide on a tire diameter and then pick the appropriate aspect ratio using a tire size calculator. Then decide if it looks right.
You might need a spacer for the front to fill out the wheel well. PS - Not an expert, just my opinion. |
DanT |
Apr 13 2011, 10:38 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
225x50 or 225x55 front
245x45 or 245x50 rear |
Larouex |
Apr 13 2011, 10:05 PM
Fixed the links on my posts on facebook had them locked to friends only, should be available for everyone now.
What about brands? Larouex |
turnaround89 |
Apr 13 2011, 10:42 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Hows this for fuchs and tires
Dunlop Direzza 205 50 R16 front and 225 50 R16 rears (IMG:http://www.914world.com/bbs2/uploads_offsite/a5.sphotos.ak.fbcdn.net-9067-1302756141.1.jpg) I love the tires, great grip and not extremely expensive. I bought mine from tire rack and had them installed by a buddy at sears |
Larouex |
Apr 14 2011, 09:05 AM
Hows this for fuchs and tires Dunlop Direzza 205 50 R16 front and 225 50 R16 rears (IMG:http://www.914world.com/bbs2/uploads_offsite/a5.sphotos.ak.fbcdn.net-9067-1302756141.1.jpg) I love the tires, great grip and not extremely expensive. I bought mine from tire rack and had them installed by a buddy at sears Those sizes fit the 16x7" and 16x8"? I like the profile... Larouex |
turnaround89 |
Apr 14 2011, 09:30 AM
Absolutely, i have the same rims on my car 16x7 in the front and 16x8 in the rear
Tire Rack Tire Size/Rim Size If you look at the middle column that says Rim width range, you can see all the rim widths that the dunlop tire will fit and all the sizes the tire comes in. This is how i figured out what tires to get for my car. You can look up the info on what size tire fits what size rim for all tires that tire rack offers. I just used the dunlop as an example, hope this helps The thing i liked most about the tires, is that the rim sits inside a nice gap of tire, so if you accidentally scrap a curb, the sidewall of the tire takes the beating and not the rim. Once you buy the tires, just take them to any tire shop and have them mounted and balanced. I ran into the same issue when i looked for tires, the tire places wanted a year, make, model and kept telling me my rims won't fit the car and that going off the the width of the rim doesn't tell them anything about what tires will fit. I said screw talking to them after awhile because they weren't helping and went the tire rack route. My tires fit perfectly and they look fantastic. Would recommend these tires to anybody |
IronHillRestorations |
Apr 14 2011, 01:19 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
225/55 or the 205/55 up front. The wider tire makes low speed turning and parking more arm wrestling.
I'd go with 245/45 in the back. Get the best tire you can afford. Dunlops are good, Pirelli's and Michelin's are better but cost more. I've gone even cheaper on tires, and regretted not spending more and getting better tires. |
racerbvd |
Apr 14 2011, 01:55 PM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
225 is the widest that I would go on an 8X16, yes, a 245 will fit, but it bulges losing any benefit of the wider tire by increasing the flex in the sidewall. Just because something kits, doesn't mean it is a good fit, think of fat chicks in spandex at the mall.
DanT |
Apr 14 2011, 03:42 PM
225 is the widest that I would go on an 8X16, yes, a 245 will fit, but it bulges losing any benefit of the wider tire by increasing the flex in the sidewall. Just because something kits, doesn't mean it is a good fit, think of fat chicks in spandex at the mall. The factory put 225s on the rear of SCs and Carreras on 7x16s. (IMG:style_emoticons/default/smile.gif) |
racerbvd |
Apr 14 2011, 08:13 PM
225 is the widest that I would go on an 8X16, yes, a 245 will fit, but it bulges losing any benefit of the wider tire by increasing the flex in the sidewall. Just because something kits, doesn't mean it is a good fit, think of fat chicks in spandex at the mall. The factory put 225s on the rear of SCs and Carreras on 7x16s. (IMG:style_emoticons/default/smile.gif) Yes, and that does work, but 245s don't work well on 8X16s. |
DanT |
Apr 14 2011, 08:24 PM
Interesting, I just checked on tirerack.com and the 245x45and 245x50 were all measured for specs on 7.5" or 8" rims. (IMG:style_emoticons/default/confused24.gif)
ConeDodger |
Apr 14 2011, 08:47 PM
Apex killer! Group: Members Posts: 23,613 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Pending final measurements, I plan on putting the 245's on 8.5" custom Weidman Fuch wheels when I put the flares on...
DanT |
Apr 14 2011, 09:03 PM
That should look great Rob...Are they 16" Fuch centers on BBS hoops?
Ran 255s on 8.5s on my Boxster and 964 C2 (IMG:style_emoticons/default/smile.gif) |
ConeDodger |
Apr 14 2011, 09:24 PM
That should look great Rob...Are they 16" Fuch centers on BBS hoops? Ran 255s on 8.5s on my Boxster and 964 C2 (IMG:style_emoticons/default/smile.gif) No Dan, Harvey made two 16X8.5 out of four 16X6 wheels. Pretty popular thing to do as you can do it for less than buying a pair of 8's or 9's... Probably why it is getting harder to find 6's! |
DanT |
Apr 14 2011, 09:26 PM
Nice!
Larouex |
Apr 14 2011, 09:28 PM
Awesome, I am smart now thanks your experiences, that is why I love this forum.
LOL BTW for this one... << ... think of fat chicks in spandex at the mall. >> I do think about them, that is the problem! Larouex |
stugray |
Apr 14 2011, 09:35 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Lo-Fi Version | Time is now: 9th June 2024 - 05:44 PM |
