Help !!! I am stuck..., FI - Fuel Pump Relay |
wheelo |
May 13 2004, 07:20 PM
Dude Group: Members Posts: 265 Joined: 19-March 04 From: San Rafael, Ca Member No.: 1,818 |
914 Guru's... Please help, I replaced all my old fuel lines and relocated FI- fuel pump under gas tank. As PO had all wrong with filter on wrong side of pump etc. Everything was running great before, just doing restro and preventitive maint.
Well, turned the key after putting all together, no running fuel pump! Took a look at wiring at plug (MPC) and found bad splice on brown- ground wire. Repaired splice, should work right? wrong... still no juice to plug/wire.. I am starting to think that the fuel pump relay went-bad. All the relays look the same to me, Is there a fuse that I am overlooking? All fuses in the panel are okay, Please advise... I am stuck !! and WCC is coming soon! I will be eternally grateful... (IMG:style_emoticons/default/pray.gif) |
TheCabinetmaker |
May 13 2004, 07:23 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
did you check the fuse on the relay board?
r_towle |
May 13 2004, 07:26 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
The fuel pump relay and fuse are on the relay board in the engine compartment right behind the driver.
All of the relays in there are the same, so swapping them till you get the whirring sound is fine for testing. You might have just blown the fuse... Rich |
wheelo |
May 13 2004, 07:48 PM
I see two fuses on the relay-board both are good. Is there another one ? somewhere.... The manual speaks of a 8A fuse at relay terminal 35/51. I am confused... M.M.
SirAndy |
May 13 2004, 09:00 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
you only need the second fuse, 25Amps. marked green here ...
the relay is also marked green, exchange it with one of your headlight relays (if the headlights still go up/down). make sure the relay pins and the socket is clean, if not clean up first (with key turned OFF) ... Attached image(s) |
SirAndy |
May 13 2004, 09:03 PM
from there power goes to pin 13 (black/red wire) on the connector right next to the firewall. you can take the top cover off the connector and see if the pin got 12V when you first turn on the key.
also note that the FI brain will turn off the fuel pump unless the car is started! so make sure everything is hooked up right on the other end, from the relay board to the FI brain and all grounds are good there. you'll also need the tranny ground strap connected for this to work (IMG:style_emoticons/default/wink.gif) Andy Attached image(s) |
SirAndy |
May 13 2004, 09:04 PM
also, do a search here on the bbs, we just went through this exact same thing like 2 or 3 weeks ago ...
Andy |
wheelo |
May 13 2004, 11:59 PM
Thanks Sir Andy... viel danke..for the help and schematics... I will get-on this first thing in the AM!By the way I have 25A fuses in both slots on relay board. Your drawing shows 8A in first (forward) and 25A in second. Should I change-out first fuse to 8A?
appreciate the responce, I owe you a cold-one (IMG:style_emoticons/default/beer.gif) |
Dr Evil |
May 14 2004, 12:04 AM
I think that the otherone was for an option not installed on every car I have seen. Here is my rough schematic for your troubleshooting pleasure.
Attached image(s) |
SirAndy |
May 14 2004, 12:11 AM
QUOTE(wheelo @ May 13 2004, 10:59 PM) By the way I have 25A fuses in both slots on relay board. Your drawing shows 8A in first (forward) and 25A in second. Should I change-out first fuse to 8A? appreciate the responce, I owe you a cold-one (IMG:style_emoticons/default/beer.gif) from what i can tell by looking at the wire diagram, the first fuse (8 Amp) is not used at all, it routes 12V (which it get's from Fuse 8 in the main block) to Pin 9 on the engine harness connector on the relay board and i can't find any drawings that show anything ever beeing hooked up to pin 9 ... soooo you should be able to leave that fuse out. which means, you should leave the 25Amp in there so you always have a spare with you! (IMG:style_emoticons/default/wink.gif) Andy |
wheelo |
May 14 2004, 12:40 AM
Thanks Guys... the support really helps.. I can't stand having my car in the garage, knowing that she is temp. out - of- commission!
pbanders |
May 14 2004, 08:39 AM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
I have a comprehensive flow chart on my web page for debugging the FI fuel pump system.
http://members.rennlist.com/pbanders/ |
Lo-Fi Version | Time is now: 10th June 2024 - 12:48 AM |
