Headlight problems, They flash all the time |
brians914 |
May 19 2004, 08:49 AM
Newbie Group: Members Posts: 31 Joined: 16-March 04 From: Minnesota Member No.: 1,805 |
I decided to take a drive last night and when I came back from a friends it was dark. I got 1/2 way home and my headlights started flashing from low to high beam. The low beam on the driver side went out also. I was able to slow this down by holding the lever but it would still do it. The county policeman pulled me over and I explained the problem and he then led the way home for me, nice guy. Does anyone know why this is? Is it the turn signal switch or what?
Thank, Brian |
mike_the_man |
May 19 2004, 01:49 PM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
I have no experience with this, but it sounds like something is loose. It might be worth pulling the column apart and having a look to see if anything is jiggling around. I would start with the switch, and work from there.
brians914 |
May 20 2004, 07:45 AM
I will give that a try, thanks Mike.
cha914 |
May 20 2004, 09:33 AM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
Sounds like your relay is going out. There should be a silver (both mine were silver) relay around your fuse pannel that controls the high/low beam switching. Mine went out a while back and I lost my high beams, pulled the one out of the parts car and the problem was fixed.
Good luck, Tony |
brians914 |
May 20 2004, 10:24 AM
Thanks Tony, I"ll try that before I take the wheel off. I think I know what switch your talking about.
Lo-Fi Version | Time is now: 8th June 2024 - 04:50 AM |
