Match-port mani/head, How? |
Dave Cawdrey |
Apr 15 2003, 11:15 PM
Dumbo going poop, Daddy :) Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 |
I assume you put some material (grease, RTV, etc?) on head, then test fit/mate the surfaces, and remove material from manifold side with high rpm tool. Dremyl work?
I am thinkin bout trying this. Any tips or recommendations? |
Bleyseng |
Apr 16 2003, 12:21 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Yeah, you use some sort of marking agent. A dremel is pretty weak dude, a high speed diegrinder with a aluminum grinding bit works good. You want to make them all the same too.
Geoff |
rhaas |
Apr 16 2003, 06:27 AM
Member Group: Members Posts: 63 Joined: 16-January 03 From: Bay Saint Louis, MS Member No.: 155 |
I use the gasket as atemplate for both sides. Makes matching them real easy.
thesey914 |
Apr 16 2003, 10:26 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
Also it's worth match porting the carb and manifold interface too
Lo-Fi Version | Time is now: 13th June 2024 - 06:22 AM |
