Fuel Lines?, original sizes |
Russ K |
Apr 16 2003, 01:38 AM
Newbie Group: Members Posts: 45 Joined: 7-April 03 From: SF peninsula, CA Member No.: 535 |
Hey, i'm in the process of re-plumbing and i was a bit curious about the original fuel-line diameters. I have a 73 1.7L and all of the various nipples *seem* to be set up for 8mm hose except two in the front trunk for the gas-tank return line (6mm?). I was curious where that thinner return line actually made the switch to 8mm.. is the "t" piece near the fuel pump suppsed to have a one mipple thats smaller than the others? (mine appears to be all 8mm.. but maybe it's aftermarket)
In a bit of research i was lookng at the pelican websiite and noticed they are specifically selling 3 different diams in their 914 section. I'm hoping the 7mm is for a different year/set-up? but i dont know. Anyways.. i realize none of this is critical to getting my car running again.. but i figured i'd ask in the hope that everything will fit together as smoothly as possible. thanks. |
SirAndy |
Apr 16 2003, 11:12 AM
Resident German Group: Admin Posts: 41,682 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Russ K @ Apr 15 2003, 11:38 PM) is the "t" piece near the fuel pump suppsed to have a one mipple thats smaller than the others? (mine appears to be all 8mm.. my "Tee" is also all 3 same size. it's a b**ch to get the lines on (IMG:style_emoticons/default/cool.gif) my car's a early '70 ... my plastic fuel lines seem to be the same size, both at the front and the end !?! |
Lo-Fi Version | Time is now: 13th June 2024 - 01:43 AM |
