To wrap or not to wrap, exhaust headers for six |
kfish914 |
May 2 2011, 03:50 PM
Member Group: Members Posts: 161 Joined: 7-May 08 From: Osceola, Indiana Member No.: 9,026 Region Association: Upper MidWest |
I am still working on installing a 2.7 six into my car and I was thinking about wrapping the exhaust to cut down on heat transfer. I have heard that it can't hurt, that it actually keeps the exhaust gases hotter in the pipe.
What do you guys think is it a worthwhile expense or not? |
ConeDodger |
May 2 2011, 03:53 PM
Apex killer! Group: Members Posts: 23,615 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I have coated all my headers since I wrapped some years ago and found them rusted to death when I removed it...
I'd say coat them. I just had my Tangerine header recoated at a cost of just over $100... |
IronHillRestorations |
May 2 2011, 04:10 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Years ago when I did my first 6 conversion, I had the heat exchangers Jet-Hot coated, but I wrapped the exposed pipes too.
SLITS |
May 2 2011, 05:02 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I was always told that if you used header wrap the intense heat would crystalize the metal and they would eventually fall apart.
Eventually was never defined. We wrapped our race headers. |
ME733 |
May 2 2011, 05:18 PM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
Remember,....If any engine oil leaks into/or on the exhaust wrap you will have a source for FIRE., I have seen this happen...Jet coat or ceramic coat your exhaust system...remember to allow for the pipe slip on connection on the ends of the pipes , the very last 1-1.5 inches should not be coated.
Drums66 |
May 2 2011, 05:42 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Remember,....If any engine oil leaks into/or on the exhaust wrap you will have a source for FIRE., I have seen this happen...Jet coat or ceramic coat your exhaust system...remember to allow for the pipe slip on connection on the ends of the pipes , the very last 1-1.5 inches should not be coated. ...Good tip man! (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif) |
kfish914 |
May 2 2011, 06:38 PM
I sure don't want this car to go up in flames after all the years sitting in the garage. Can the average guy do this coating at home or is it better just to find some where that does it?? |
VaccaRabite |
May 2 2011, 06:42 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Find a shop. Ceramic coating is a little more involved then simple powder coating.
Zach |
Krank |
May 2 2011, 07:00 PM
Member Group: Members Posts: 140 Joined: 11-October 09 From: Winnipeg, MB Member No.: 10,922 Region Association: Canada |
QUOTE I'd say coat them. I just had my Tangerine header recoated at a cost of just over $100... Just a thought...at .50/ft, how much is it to wrap the pipes anyway? I would think you use a fair bit of it, maybe not 100 bucks worth but I don't think it lasts as long either. |
whatabout1 |
May 2 2011, 07:14 PM
Toys in Red Group: Members Posts: 403 Joined: 6-March 06 From: Charlotte, NC Member No.: 5,676 Region Association: None |
Every header I have wrapped has rusted and it didn't take long.
Wrapping was the trick back in the days before ceramic became affordable. Ceramic coating is the way to go. If you like the wrapped look then coat 1st. |
Mike Bellis |
May 2 2011, 08:08 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I had a set of V8 headers grenade on me. They were 14ga, I had them wraped for 1 year with no problems. On a trip back from SoCal the came apart at the head flange. They exploded! Pieces everywhere. I drove for 5 hours open header (open HEAD!) on I-5. When I got home, I could barely hear anything... Wrap will make the steel brittle. Make sure your muffler hangers are sturdy and no extra weight is put on the headers.
SirAndy |
May 3 2011, 11:58 AM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
JamesM |
May 3 2011, 04:05 PM
Senior Member Group: Members Posts: 1,916 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
On my eurorace headers i first tried wrap and then later had them jet-hot coated.
Don't waste time with the wrap. Jet-hot blocks the heat much better and makes the pipes last near forever, plus it looks amazing. Also, don't wrap the pipes after you coat them, supposedly its bad for the coating. |
Elliot Cannon |
May 3 2011, 09:23 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
Coat them.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 11th June 2024 - 08:28 AM |
