Crazy Carb question, Make me use my FCR's! |
monkeyboy |
May 2 2011, 08:55 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
I have a couple of motorcycle carbs laying around. Nice ones. I have a pair of FCR 41 mm carbs. This is what the high end race bikes ran before they went FI.
Here's my dumb idea... I have a set of 2 into 1 manifolds, and some carb spacers that fit them. I can have a muffler shop weld me up a 45 to the manifold and then I can use a silicone hose to mount the carb to the manifold. I can then make some sort of brace, but I will need to figure that out once the manifold is done. They have two place cable wheels on them already so I can make a single cable with the motorcycle adjuster on the first carb, and then an adjustable crossover cable on the second. Sort of like the new cable linkage that people are making for the regular Weber carbs. These carbs are new, highly adjustable, and jets are available freely at any motorcycle shop. Can anyone blow holes in this idea? Why won't it work? The only thing I can think of is that the 41's may be too large for my stock 2 liter. I could build a bigger motor later if that's a problem (IMG:style_emoticons/default/smile.gif) Any thoughts? (IMG:http://www.914world.com/bbs2/uploads_offsite/www.spracing.ch-9147-1304391327.1.jpg) This is a 39, but the carbs look the same on the outside other than the sticker. |
r_towle |
May 2 2011, 11:16 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
go for it...post pics.
Rich |
914itis |
May 2 2011, 11:26 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
jaxdream |
May 3 2011, 08:43 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
What kind of fuel pump would you use ?? Were these gravity feed or pressure fed ?? Sill worth a shot , you already have them , know what and how to adjust . Heck , I would give it a try . Let us know if you do and the results . Not a real bad idea.
Jack / Jaxdream |
McMark |
May 3 2011, 10:51 AM
Sounds like a great idea. I bet the VW Type 3 guys would love something like this if it worked because you could easily keep it all under the lid. It would make a nice low setup and you could build a common air box in the middle with a shared air filter. (IMG:style_emoticons/default/idea.gif)
I like it! |
stugray |
May 3 2011, 11:05 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I actually considered doing the same thing using the new Mikunis (modern stromberg/SU replacement).
If you get an original manifold from a single carb type IV setup, you could cut the pipes to make side draft adapters. Stu |
dirk9141973 |
May 3 2011, 11:08 AM
Unregistered |
(IMG:style_emoticons/default/smoke.gif)
Sounds like a great idea. I bet the VW Type 3 guys would love something like this if it worked because you could easily keep it all under the lid. It would make a nice low setup and you could build a common air box in the middle with a shared air filter. (IMG:style_emoticons/default/idea.gif) I like it! You got me thinking what about the motorcycle engine never seen that in thread but ??? |
IronHillRestorations |
May 3 2011, 11:25 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'm guessing the important thing would be to make sure the intakes had the right cfm's to match the engine displacement, port size, and carb size.
Great idea that would be very cool if it works well!! |
Mark Henry |
May 3 2011, 12:35 PM
Wait a minute! Wouldn't that be stealing Slowtwitch's Sync-Link cable system?
Don might not like that! (IMG:style_emoticons/default/wink.gif) |
jaxdream |
May 3 2011, 12:44 PM
Nope , Honda , Yamaha , Suszuki , etc , even Harley used the wheel / bellcrank setup on the scooters for a while , pull -pull dual cable setup. Got one on my S&S Super mounted on my 80 ci 76 FLH . Though I could be teribbly wrong and probably start another monkey poo slinging thread , of which I DON'T want any part of , period.
Jack / Jaxdream |
monkeyboy |
May 3 2011, 12:46 PM
Yup. I'm actually looking at MC cables to see what will work. That's how I plan on doing it.
jaxdream |
May 3 2011, 12:48 PM
Sounds like a great idea. I bet the VW Type 3 guys would love something like this if it worked because you could easily keep it all under the lid. It would make a nice low setup and you could build a common air box in the middle with a shared air filter. (IMG:style_emoticons/default/idea.gif) I like it! Possibly use the weber 34 ICT manifolds , hog em out some for volume. Could be wrong as hell though . I got a set of these for a Type 3 which is why I added to your post McMark , no harm intended. Jack / Jaxdream |
monkeyboy |
May 3 2011, 12:50 PM
Again, that's what I have. Not going to hog anything out until I have the carbs bolted to the manifolds. Need to talk to some welders this weekend and go from there.
JmuRiz |
May 3 2011, 01:03 PM
914 Guru Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Oooooo flat-slides, very cool!
Mark Henry |
May 3 2011, 01:10 PM
Nope , Honda , Yamaha , Suszuki , etc , even Harley used the wheel / bellcrank setup on the scooters for a while , pull -pull dual cable setup. Got one on my S&S Super mounted on my 80 ci 76 FLH . Though I could be teribbly wrong and probably start another monkey poo slinging thread , of which I DON'T want any part of , period. Jack / Jaxdream It's said with a winky....monkeyboy flinging monkey poo (IMG:style_emoticons/default/lol-2.gif) |
Woody |
May 3 2011, 01:18 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Looks like a setup off a Ducati. (IMG:style_emoticons/default/popcorn[1].gif)
stugray |
May 3 2011, 01:55 PM
Here's the mikuni website just for comparison:
http://www.mikuni.com/fs-products_guides.html (IMG:http://www.914world.com/bbs2/uploads_offsite/www.mikuni.com-10819-1304452506.1.jpg) My brother runs them on his TR4 and they work FAR better than the Strombergs and easier to adjust. I have a set of the single carb manifolds if you are interested. I also thought about the common air filter box. If you did it right, the two carbs would be almost facing each other making for an easy air box with a nice big circular air filter on top. Stu |
SirAndy |
May 3 2011, 01:56 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
You can't carb a 914! (IMG:style_emoticons/default/rolleyes.gif)
SirAndy |
I also thought about the common air filter box. If you did it right, the two carbs would be almost facing each other making for an easy air box with a nice big circular air filter on top. (IMG:style_emoticons/default/agree.gif) |
Ductech |
May 4 2011, 08:53 AM
Member Group: Members Posts: 356 Joined: 16-July 10 From: AridZona Member No.: 11,949 Region Association: Southwest Region |
Woody your damn skippy those are aftermarket for a 900 desmodue motor. Those carbs would be more than enough flow for a 900 cc two valve twin. would it be enough carb for a 914 motor?
Lo-Fi Version | Time is now: 10th June 2024 - 10:09 PM |
