Sawzall advice |
Sawzall advice |
RD Evans |
May 23 2004, 03:54 PM
Member Group: Members Posts: 112 Joined: 20-July 03 From: Temple, TX Member No.: 923 |
I have a '74 roller that I will be cutting up soon. Since I've never attempted this, I could sure use some input. What type of blade do you use? What determines the "best" places to make the cuts? The car has good quarters but is shot in the longs. How clean are the cuts made with a sawzall? How much clean up of the edges before they can be welded into another car?
Thanks for the input... (IMG:style_emoticons/default/sawzall-smiley.gif) |
morph |
May 23 2004, 04:35 PM
quality parts builder Group: Members Posts: 1,828 Joined: 25-November 03 From: oregon coast Member No.: 1,389 Region Association: Pacific Northwest |
dewalt demolition blades, also the shorter the blade is more control youll have.you want cleaner cuts get a blade made only for metal.
415PB |
May 23 2004, 05:05 PM
Member Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 |
QUOTE(morphenspectra @ May 23 2004, 02:35 PM) dewalt demolition blades, also the shorter the blade is more control youll have.you want cleaner cuts get a blade made only for metal. I totally agree and have been using the Dewalt blades. Makes a nice clean cut. Let the sawzall do the work for you, try not to force it with a whole lot of pressure. Be prepared to go through alot of blades though. |
Trekkor |
May 23 2004, 05:09 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Go to Home Depot and get the 10 pack of metal cutting blades. Saves you $. They have 6",8"and 10".
Plan your cuts, support the work. If the blade get pinched, it will bind up, bending the blade or throwing the "zall at you. Run the tool at full speed and try to cut as smooth and straight as you can. Turning in mid cut WILL bind. Ear plugs, eye wear and gloves. Have fun! (IMG:style_emoticons/default/sawzall-smiley.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 03:49 AM |
